Can anyone help tell where to locate the RPO number on a 2004 Xsara?
The sticker on the door post just has the model version printed on it "2.0HDi" - helpful or what haha!
RPO number
Roen
RPO number
- x 1988
Re: RPO number
http://www.frenchcarforum.co.uk/forum/v ... =3&t=11334" onclick="window.open(this.href);return false;
Roen
Re: RPO number
Thanks Stickyfinger I believe the post is for an earlier version of the Xsara. Couldn't find the code in the places it suggested!
- x 1484
Re: RPO number
It should be on the door sticker, but if not, post up the last 8 digits of the VIN and I'll look it up on service.citroen
PS - it's the sticker on the A piller you need to look at, the one with the tyre pressures on it. It will be an alpha numeric string - 5 numbers plus 2 letters - it's the numbers you are interested in, the letters give the factory it was built in.
Roen
Re: RPO number
Great, I have the number now thanks again for your help
- x 94
Re: RPO number
if you still post the last 8 digits of your chassis/VIN No. we can get you your cars birth certificate,
this not only give you the rp No. but also engine/box codes/types trim/paint colour/codes and much more
Regards, malcolm.
Roen
Re: RPO number
Thanks Citronut for the offer.
I bought a workshop manual online that runs on my laptop and appears to be Citroen based; you put in the VIN number and can view the characteristics of the car inc the RPO number and a heap load more info should I ever need it. So I guess it was worth the 12,99€
- x 94
Re: RPO number
not really as you can register onRoen wrote:Thanks Citronut for the offer.
http://service.citroen.com/do/changerParametres" onclick="window.open(this.href);return false;
and get all that sort of info for nout, its only the tech doc's you have to pay for
Regards, malcolm.
old-un77
Re: RPO number
but that site is for traders, isn't it?
or does one need to sign in with their fingers crossed?
Bob
Bob
Roen
Re: RPO number
Oh well, I have the files now, but thanks for the heads up Citronut.
Making slow progress as I have other issues with the car and wondering if Lexia 3 will be good to have and will I understand how to use it correctly
I have Torque on my phone that connect with OBDII but seams a bit generic in results
