Fred is leaking from her rear anti sink sphere. I need a new seal. Is it 2.5mm? Or 3.5mm? Anyway when I changed the sphere last year I foolishly changed the seal, with one from my box of seals, but it wasn't quite the right size.
Thank you.
Part number please - anti sink sphere seal
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 94
Re: Part number please - anti sink sphere seal
i think it is 4,5mm
Regards, malcolm.
elma
- x 287
http://www.eurocarcare.net/spheres/527215.html" onclick="window.open(this.href);return false;
The seal is square section with a height of 2.5mm and a width of 2mm.
I've just measured a new one to get the numbers so they are accurate.
- x 94
elmaelma wrote:http://www.eurocarcare.net/spheres/527215.html
i might be wrong but i think the OP is asking about the pipe seal to the sphere,
also pm. sent
Regards, malcolm.
elma
- x 287
Yes of course, anti sink sphere.
Sorry got the wrong end of the stick.
Xantidote
- x 5
- Yescitronut wrote:i think it is 4,5mm
Martin
1995 Xantia TDLX (deceased
- x 94
99% of the time the pipe seals are reusable, just mind you peel/pull and strands of rubber off that might be sticking out
Regards, malcolm.
Jaf
- x 42
Thanks all. Yes I did mean the pipe seal. Helps if I say it properly! Predictably I threw the old seal away. Anyways Citroen peeps can't find the seal on their computer. But I'm sure I can find another seal now that I know the size.
Thanks again.
Thanks again.
- x 3306
If you have one of the old square section seals that the normal spheres use I would use that on the anti sink sphere as well. Not for sealing purposes, but to stop the sphere binding onto the mounting bracket.
Jaf
- x 42
Well no wonder the poor thing is leaking. I put a standard o ring in there! Sigh. I'll be the one in the corner, with the dunces cap on...
