Hi
Just wondering if anyone has a how to guide on replacing the oil seal in my gearbox where the drive shaft goes fits into.(passenger side) please. 2004 Berlingo 1.9d
I am assuming it is the oil seal.
I replaced the strut yesterday and while replacing it the hub pulled the drive shaft out a little bit and oil started to leak from the gearbox. i pushed the drive shaft back in which stopped the oil(or so i though) coming out quickly but when i got up this morning there is a drip coming from the gearbox where the shaft goes in.
Berlingo drive shaft oil seal replacement advice please.
tmm
Xantidote
- x 5
Re: Berlingo drive shaft oil seal replacement advice please.
Always a possibility the drips you are seeing is just residual oil from the initial leak, unless you cleaned the area up thoroughly afterwards. Otherwise, maybe somehow you've damaged the seal on refitting the drive-shaft?
Martin
1995 Xantia TDLX (deceased
tmm
I was hoping that's all it would be but its still leakingXantidote wrote:Always a possibility the drips you are seeing is just residual oil from the initial leak, unless you cleaned the area up thoroughly afterwards. Otherwise, maybe somehow you've damaged the seal on refitting the drive-shaft?
- x 94
well you have already near as dam it hed the shaft out of the box already,
the next time on intentionally pulling the shaft out place a tray under the diff, normally expect to loose about a liter of gear oil, so unless you intend to drain the full box content ( gear oil change ) just refill with one liter of new 70/80 oil of the correct spec for PSA box's
once you have the shaft clear of the box, wipe the area around the shaft port in the diff, then with a large screw driver place the tip up inside the seal and prise it out of the diff/gear box, it usually comes away very easy without any force,
then re/wipe the area and press/tap the new seal home, mind the outer edge is flush with the edge of the diff casing
Regards, malcolm.
tmm
Thanks you citronut that is the answer i was looking for
I thought maybe i had to loosen something else off maybe the ball joint or something along them lines.
So basically if i just take the bottom of the strut out and pull the hub(on an angle from top to floor) the shaft will come all the way out of the gearbox? for me to change the seal?
- x 94
i personally do split the lower swivel on doing this job,tmm wrote:Thanks you citronut that is the answer i was looking forI thought maybe i had to loosen something else off maybe the ball joint or something along them lines.
i think it is a bit/very tight to get the shaft out of the box by just splitting at the strut to hub carrier,
Regards, malcolm.
addo
- Sara Watson's Stalker
- x 95
tmm
Thanks everyone for the help its really appreciated.
I loosened the bottom ball joint then pulled the drive shaft out and replaced the seal that way.
cancunia
Same thing just happened to me but looks like I'll need to replace the oil too as I've drained out over a litre to be sure it's under the level of the shaft. I have a 2004 2.0HDi but assume its the same procedure?
ekjdm14
- x 251
Pretty much the same for all PSA left diff seals AFAIK & for the peace of mind it's worth changing the gearbox oil as well unless it's only been done recently.
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
mickeymoon
cancunia wrote:Same thing just happened to me but looks like I'll need to replace the oil too as I've drained out over a litre to be sure it's under the level of the shaft. I have a 2004 2.0HDi but assume its the same procedure?
It is, but you might have the one-piece lower arm like mine does, and you'll have to split the ball-joint to pull the shaft. I pulled it out by accident when changing the lower arm on mine.
cancunia
Thanks for both of your replies, looks to be something I can get done without too much bother. The additional groan factor is that I put a litre of new oil in before I realised it was still leaking! Ah well you learn all the time I suppose. I have saved over a litre of oil in clean containers, but the oil is not the same colour as the stuff I put in earlier.
Is there a trick to splitting that ball joint? I've seen a diagram that seems to show a lever under the gearbox with a chain around the bottom arm, do I just need to apply some leverage, or does it need a tap as well?
mickeymoon
I'd advise getting either a splitter, or a Hell Razor James with patience and a big hammer!
I had no splitter, and it was a total pain in the arse. In fact, James came round and attacked it with a big hammer and I went off to buy a splitter. He phoned me to tell me he'd got it off just before I bought it!
- x 3283
Mind you, I did not know that I had to tighten up the clamp a lot tighter than I did. Fortunately we had a friendly MoT tester, who not only understood what I had done wrong, but had the tools (and inclination) to correct my mistake.
cancunia
I think I'm ok on the hammer front and may even have a ball joint splitter somewhere so will get on with it once it gets a bit warmer outside.
On the subject of seals, I see that there are 2 types on offer. One is the standard shaft type oil seal and the other type has a nylon cage which I guess is intended to protect the seal & guide the shaft. Anyone tried a plain standard seal without the cage successfully?
