Activa rods
Matt H
Activa rods
Unread post by Matt H »
I recently changed the Activa rod bushes, and found that the rods themselves are badly worn. I thought that they were still available from Citroen, but it seems that one side is now NLA :?
After talking with a former Activa owner recently, he reckoned they could actually be repaired...
Anybody ever tried?
x 8441
Re: Activa rods
No, but I've thought the same Matt.. Build then up with Chemical Metal and grind/sand back...
That should last a while as long as they're kept well greased...
A skilled person might be able to build them up with weld too...
New nylon guides are easy to make...
Matt H
Re: Activa rods
Interesting! I certainly think that it's something i'd like to try. Can't make it any worse than it is now!
Any tips for removing them? I've heard that it can be a bit of a pain...
x 8441
Re: Activa rods
Matt, the rods are not hard to separate. Just move the ball and socket to the maximum extent of their travel and keep going a bit... A bit like dislocating a shoulder...
