Windscreen wiper hose
sandysound
Unread post by sandysound »
The windscreen wiper hose on my Xantia II has been severed - How should I repair it or is it easy to replace? It looks like it disappears down towards the wheel arch but then I can't see it anymore :/
Advice please!
x 1240
Re: Windscreen wiper hose
Unread post by Peter.N. »
You may be able to find a plastic joiner in a garden centre or failing that a piece of metal or plastic tube pushed inside it.
sandysound
Yes I was thinking of an aquarium hose joiner. Do you think it would handle the pressure?
Or a hose over the top and glued... Thoughts?
Zelandeth
x 1608
Unread post by Zelandeth »
Pressure shouldn't be too extreme (use cable ties as hose clips to help!), provided the jets aren't blocked.
Mine kept blowing the hose off where it goes onto the bonnet edge - until I cleaned the jets all out. Has been fine since.
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
x 1240
Yep, an aquarium hose connector should do it, or an automatic watering system connector.
x 94
Unread post by citronut »
the likes of this would do the job
http://www.europaspares.com/mechanical/ ... 4-8mm.html" onclick="window.open(this.href);return false;
just warm the ends of the old pipe with a lighter or the likes,
although you dont realy want this type of repair were the pipe is being flexed constantly
Regards, malcolm.
harryp
(Donor 2022)
x 75
Unread post by harryp »
fixed mine by sliding the next size up tube over it, overlap by say 2" either side. Did not use glue, has never leaked. Routing is crucial as it should twist rather than bend for a longer life. There is a comment on this by Hell Razor in an earlier post IIRC.
HTH, Regards
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
sandysound
Thanks for hints! The car had an incident at 3:30am last night but this still needs to be done and looks like an easier fix than I originally thought! Will do the bigger hose over the top. Cheers!
x 94
sandysound wrote: The car had an incident at 3:30am last night !
is this another way of saying !pilot era" :twisted: #-o :-D :lol: :wink:
Regards, malcolm.
sandysound
In a way... just not my piloting error - read here:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=50377
