Xantia needs some love
sandysound
Unread post by sandysound »
Hello,
I am new to the forum so a snowy hello from Norway!
I am also new to a pre owned Xantia which needs a little TLC.
I have a small list of "to do's":
* Figure out which model I have! Done - Thanks vborovic!
* Find an owners manual (it didn't come with one!) Done - Thanks vborovic!
* Fix Interior Lights. Done! Gave the prongs on the bulb holders a bend to make a better contact.
* Windscreen Wiper Fluid Hose has been cut - replace or repair?
* Drivers side rear, Passenger side front and rear electric windows do not work.
* Rev counter idles at the 3000 mark - when clearly it is more like 1000
* Fan for the heater/cooler is either on full or not at all.
* Read Drivers Side Door does not lock/unlock with central locking. Only manually from the inside.
* Aftermarket stereo install is seriously stuffed up. Left is Right, and Right is Left AND None of the speakers on the Drivers side work - Front or Back! There are other issues too...
So I think its best to start at the top of the list and work my way down. I will probably create different posts for each item as I go but I might as well begin here so...
I think its a 2010... But need some help to determine that. It was first registered in 2010 according to the paperwork...
It's a 2000 Xantia II
How do I tell what model it is from the vin?
What do you think?
vborovic
Locked user account
x 40
Re: Xantia needs some love
Unread post by vborovic »
Welcome aboard, if you share with us your VIN (chassis) number, we could tell you about your car when it left the production line ... an owners manual could be obtained from ebay (used) in paper form, or probably some folks here have it as a digital copy ... the Xantias weren't manufactured after 2002, so I don't know how yours could be from 2010 (time travel is still not available) ...
sandysound
Ha ha yeah that makes sense - VIN number is:
sandysound
Would settle for a digital copy of the manual if there is one about...
vborovic
Locked user account
x 40
Vehicle characteristics
Vehicle family XANTIA II
AS RPO No 08487 U7 2 0105
Warranty Start Date 25/05/2000
Engine serial number 10 DYCQ 4006467
Gearbox serial number 20 LE84 0396724
OPB A01T
BER e2*98/14*0180*01
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XANTIA II
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL SX
ENGINE DW10ATED TURBO DIESEL
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EHJ - PAINT - CRIMSON
INTERIOR TRIM TYPE OMEGA CLOTH + "LM" MOLLETON
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) BVM ML5T
ENGINE (TYPE) EW/DW
OTHER BADGE 2 0 HDI
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE HDI
TRIM LEVEL SX
SPEEDOMETER DRIVE TACHO TORQUE 25X20
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3 PARTS CATALYST
LPG FUEL TANK WITHOUT LPG TANK
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
VEHICLE TECHNICAL DEPOLLUTION L3 VEHICLE TECHNICAL DEPOLLUTION
FAN 2 FANS , 2 RATES , IMPROVED
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
WHEEL STYLE STEEL WHEEL
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 20
SEAL, DIFFERENTIAL END REAR AXLE SIDE JOINT JB3A
GEARBOX TYPE (TYPE APPROVAL) GEARBOX ML I TYPE
TYRE (SIZE, TYPE) 205X60X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX ML
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 23
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
HYDRAULIC STOP WITHOUT HYDRAULIC STOP
REAR SUSPENSION SPHERE RR SUSP SPHERE UREPAN
ACTIVE ANTI-ROLL W/O ACTIVE ANTI-ROLL
FRONT SUSPENSION SPHERE FRONT SUSP SPHERE WITH "NOK" MULTI-LAYER MEMBRANE
MAIN ACCUMULATOR SPHERE UREPAN ACCUMULATOR SPHERE
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
WHEEL EMBELLISHER (STYLE) BACCARAT STYLE 8 HOLES 15 INCHES
WASHER JET WINDSHIELD WASHER JET WITH DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT INDEXED REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING BULKHEAD + BONNET SOUND-PROOFING
WINDSCREEN WIPER INTERMITT AUTO FR WIPER BLADE + WATER LEVEL
HEADLAMP WIPER HEADLAMP WASHWIPE
FRONT PANEL BLANK SEMI-CLOSED GRILLE + OPEN BUMPER
BUMPER BODY COLOUR FRONT/REAR BUMPER
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
EXTERIOR ACCESSORIES RRVIEW MIRROR CASING BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT JOINTED REAR HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITH REAR ARMREST
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
SPEED GRADUATIONS GRADUATION KMS/H
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITION LEFT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
DASHBOARD EQUIPMENT FACIA PANEL WITHOUT WOOD
MISC. INT. LAMPS MAP READING LIGHT DRIV+PASS
DOOR TRIM DOOR PANEL WITHOUT WOOD DECOR
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER MOUNTING 6 LOUDSPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER LUMBAR ADJUSTMENT
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE OIL LEVEL WARNING INDICATOR
HEATING ELEMENT HEATED SEAT
FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG
FOOTWELL LIGHTING DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
RADIO RECEIVER RADIO EQUIPMENT
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
STORAGE (OTHERS) LOWER SETTING BOX FR AND RE DOORS
LOAD SPACE STORAGE W/O BOOT TIDY
RADIO HOUSING RADIO HOUSING WITH FLAP
CARPET CARPET F470
LIGHTING TIMER ADJUSTABLE TIMER
EXTERIOR TEMPERATURE (SCALE) EXT TEMP INDICATOR CELSIUS
SWITCH ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR WATER TEMP INDIC +RED TELLTALE
FLOOR MAT W/O CARPETMAT
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L3 450
STARTER MOTOR CLASS 6 STARTER MOTOR
SPECIAL LIGHTING DAYLIGHT RUNNING LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SURFACE CONDITIONS GOOD TERRAIN
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE
vborovic
Locked user account
x 40
A more readable form is on the following link (PDF): http://www.filedropper.com/xantiaii" onclick="window.open(this.href);return false;
vborovic
Locked user account
x 40
Here you can download the Service Manual ('96 year): http://manualmadness.com/citroen-xantia ... ir-manual/" onclick="window.open(this.href);return false;
Technical manual here: http://www.manualslib.com/download/7863 ... antia.html" onclick="window.open(this.href);return false;
sandysound
Wow. Information overload! Thanks heaps! Thats 2 more things on my list struck off.
Will read a bit more of the forums now I have this information!
Cheers!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Interesting to read your Chassis is VF7**************[VIN obfuscated, can be read by forum staff], where RHZ is the 110 HDi engine, but UK xantias were all VF7**************[VIN obfuscated, can be read by forum staff] ....
Wonder why yours is a 2, estate/wagon prehaps?
Your rear door locking not working electrically will be the wires between the back door and B pillar inside the Rubber Grommet...
Pull the grommet out and move it back, id be quite sure you will find broken wires.
Blower motor will be the transisters on the Blower control board, you need to drop it down and swap them for news ones, or find one from another Wrecker with Air Condition.
A very sad...
1994 XM 2.1 d auto
electronmirror
x 30
Unread post by electronmirror »
It may be estate specific, mine begins VF7**************[VIN obfuscated, can be read by forum staff]
Take care when buying replacement transistors if you opt to replace them rather than using a second hand unit from the breakers. I've heard of NPN types being supplied whereas they should be PNP type (Motorola MJ11015).
There is a very useful guide to replacing these transistors here on the forum written by CitroJim.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
sandysound
Thanks guys for the advice, I am in Norway so not sure as to the car's history.
Interestingly the speaker in that door is not working either so inside that rubber grommet in the door hinge area would be a good place to check. Thanks again for the tips!
c.morewood
x 55
Unread post by c.morewood »
God Kveld sandy sound,
Thinking about your problem left is right osv.
Is it possible the connections at the back of the radio have either been swapped or inserted upside down by mistake?
Just a thought...
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
sandysound
Hi C.Morewood,
The stereo situation is all shades of messed up - there are multiple issues, left is right and right is left is an easy fix as you suggest, but the left side doesn't work or only works intermittently. The wiring through the door rubber grommet is the first place I will look for that. Then there is the case of the missing remote control functions - there is a connector not plugged in which I suspect is the remote wires from the steering wheel but I believe I need an adapter as the stereo is an aftermarket sony with 3.5mm jack input for the remote. The antennae does not operate as it should and the adapter loom for the stereo seems to be incorrect. I am leaving this alone till I can figure out my more important and pressing issues!
sandysound
My "to do" list keeps growing as I remember more faults ha ha! This car is going to keep me busy for a while!
c.morewood
x 55
"This car is going to keep me busy for a while!"
Yes but it will be worth it in the end.
You've made the first and best step, by joining this forum. There's lots of experience here.
But I think you'll also need a garage, preferably with a pit, where you can work on the car in the warm!!
Where, in Norway are you?
'94 Fiat TipoTd 40K
