Xantia front regulator ticks
- x 5673
Re: Xantia front regulator ticks
What you refer to as the 'master cylinder' is the doseur valve Chetiya.
- x 94
that is the doseur valve,Chetiya Dias wrote:Because this problem occurred only after I replaced the seals of the brake master cylinder.
so you have probably caused the issue
Regards, malcolm.
- x 3296
Did you replace the seals with normal rubber ones, or with LHM resistant ones. If you used rubber seals the LHM will have rotted them in short order.
Chetiya Dias
No I replaced with genuine seals. Malcolm please advice me how to sort this issue. Also there are no external leaks after replacing the seals.
2000 Xantia 2. 2.0i 16v
OnlineCitroJim
- x 8403
I'd agree the dosuer seals are the cause of this issue...
Try another rebuild with a new set of genuine seals. Or else swap the dosuer for another known good one. They’re not heavy so if you don't have one available locally I'm sure it would not be too expensive or difficult to send you one......
Chetiya Dias
Ok Jim what may have I done wrong when replacing the seals.
Chetiya Dias
Jim is it possible for you to post me a good refurbished dosuer.
OnlineCitroJim
- x 8403
Not me I'm afraid, I have none and I trust others to refurbish hydraulics... I'm not good enough to do that... Sorry.Chetiya Dias wrote:Jim is it possible for you to post me a good refurbished dosuer.
Chetiya Dias
What do you recommend to replace the seals again and see or replace the dosuer at once.
- x 5673
You will probably have great difficulty finding a replacement. They are no longer produced and second hand ones are not easy to come by. There was someone from JCB on here not long ago looking for them as they are fitted in some JCB earth movers that have hydropneumatic suspension.
Chetiya Dias
Also I noticed froth in the filter of the LHM tank when presing the brake pedal. Is this normal.
- x 94
speak to Martin at
Pleiades
Sawtry,
Cambs.,
PE28 5XF.
phone No.
01487 831239
Email: pleiades@tesco.net
he has been overhauling citroen hydraulic components for many years
Pleiades
Sawtry,
Cambs.,
PE28 5XF.
phone No.
01487 831239
Regards, malcolm.
Chetiya Dias
I checked the front anti sink valve under the LHM tank and I noticed it was little wet with oil. So I replaced it with a second hand unit. Now ticking increases over one minute and when pressing the brake pedal it reduces to 15 secs and there after it keeps on increasing to over one minute. The stop light also goes off quickly. Is this OK.
Chetiya Dias
- x 1996
Hi Chetiya.....Happy New Year to you and Sri Lanka
It is the Holiday season at the moment and often the guys are under "orders" from the lady of the house
...and they must be obedient at this time of the year
Your problem will take some working out and there are only a few to assist with the required skills......
no need to remind them/push them to answer, they will reply when they can.....
