Not Citroen but I will ask anyway
daviemck2006
x 496
Unread post by daviemck2006 »
Please dont all take the huff and ban me cos Im gonna ask something about a ****. Leaking petrol tank so it could be a citroen! Is there anything I can do to stop a leak on the petrol tank. It's leaking on the seam about 1/2 way up the tank. It got filled to the neck and 30 miles later was just over 1/2. Up on the ramps and can see a steady drip, like about every 4 to 5 seconds. I used it today and did 50 miles deliberately to get the fuel level down. It is now not dripping about 1/2 way between 1/2 and 1/4. So it will need a tank, but cant find one locally. Who said ford escort bits were got anywhere? So is there any substance I can get to put over the leak that seals it. We have decided, and I am using this pile of poo just now, just to run it until the light comes on and only put it £10 at a time and carry a gallon in the boot. Not the best Idea. If it could be bodged somehow that would see it til we find a tank it would be good. Cant really get my mate to weld it,,,,,,,,,,,,,
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
old-un77
Re: Not Citroen but I will ask anyway
Unread post by old-un77 »
there used to be a substance, was a resin catalyst lump, that was supposed to be able to seal underwater leaks in swimming pools,
called Pig Putty. in a plastic tube, cut off a bit mash it between your fingers, and apply to the area...........google "hot pigs" if I recall correctly.
I HAVE managed in the past to do a temporary repair with Araldite..........best o luck.......
sparksie
x 33
Unread post by sparksie »
I can't find it any more, but there used to be a product called "Slosh", specifically for sealing up pin holes in petrol tanks.
It takes just as much work as replacing the tank, but if a tank is not available...
What you do is remove the tank, clean it out thoroughly (we used a steam washer), dry it (warm room/dehumidifier), then slosh this stuff around inside it, coating the whole inside.
When set, the result is a plastic-like coating on the inside of the tank. It can be a pain, though, because it will happily block the holes you want to keep free, too!
As a last resort, it could be the answer, if you can find it.
Try car restorers/classic car publications, as that would be the target market for this stuff.
I'm not sure it's compatible with non-metal tanks, so check first, if you want to use it on anything more modern than your Ford.
Sparksie
2000 Xantia 1.9TurboD
x 94
Unread post by citronut »
i think what old-un77i is talking about is
http://www.ebay.co.uk/itm/CARGO-QUIKSTE ... 0699425913" onclick="window.open(this.href);return false;
this is the correct stuff for petrol tank repairs
http://www.granvilleoil.com/product_info.php?prod_id=2" onclick="window.open(this.href);return false;
or if you brave enough you could run some braze along the tank seem :yikes: [-X :-D :lol: :wink:
Regards, malcolm.
x 2941
Petropatch does work pretty well.
Please citronut don't suggest putting a flame near the petrol tank even in jest, there are some out there who are daft enough to give it a try.
x 1981
Unread post by Stickyfinger »
BOOM
daviemck2006
x 496
I've found petropatch on ebay, I also found a new tank for £58 on ebay. If it seals with petropatch would that pass a mot when the time comes? The car is quite sound and Shaun still wants to keep it.
Peugeot boxer 2016
In the family
x 1981
IF there is no leak at the time of inspection and no damage repair that looks like it will fail soon, then it will pass the MoT.
daviemck2006
x 496
I've let my son know the options, and its up to him now. It's his car and I wont have to use it again shortly. He is 20 and should be finding out this stuff himself. So if I ask anything else about a fraud tell me to bugger off :rofl2:
Peugeot boxer 2016
In the family
x 5634
I repaired my daughter's fiesta tank with Petropatch. Lasted about six months but gave us time to find a replacement.
Tank was very rusty along the seams.
daviemck2006
x 496
It's basically petropatch for a tenner, probably a temporary fix which will last until mot time and see what else it needs, or new tank 58 quid, proper fix. Personally I wouldn't look for a used one from a scrappy when new is only 58. It's up to him now.
Peugeot boxer 2016
In the family
x 94
DOH your no fun,
:eye: :eye: :yikes: :missile: :missile: #-o :-D :lol: :rofl2: :rofl2: :wink:
sirie ass lee ( as Benny Hill would say ) what was i thinking
Regards, malcolm.
Northern_Mike
Gibbo2286 wrote:Petropatch does work pretty well.
The issue is here that it is possible - I've watched it being done - an old Commer camper having its tank welded .. BUT unless it's done properly it's (-expletive removed-) dangerous.
x 2941
I've done them myself when there's been no alternative Mike but as you say it does need proper know how and great care, not a job for the average diy man.
Back when I was in business I had the boys from Badfinger music group as customers, they had a Jaguar XK150 which had petrol pouring from a leaking seam which was not fixable with petropatch and no new tank available. Their roadies took the tank out and completely wrapped it in Holts fibreglass sheet so in effect they had a tank within a tank.
old-un77
sad, innit, the way memory plays tricks, not hot pigs..........hot hogs
the stuff I recall is this....we used it when I was at work to reclaim holes for captive bolts on test bed jigs........I had no Idea of its price.....LOL
http://www.newpig.com/pig/us/top/epoxy-putty" onclick="window.open(this.href);return false;
Bob
