Can you believe it?!!!! C5 door handle snapped off.
Rawce
Re: Can you believe it?!!!! C5 door handle snapped off.
Unread post by Rawce »
Further thread resurrection!
I'm currently replacing the very same handle too. £19 off eBay. Hopefully it won't end up being a waste as I've just battled with replacing the undertray to stop the awful noise I'd get going over speed bumps, pot holes and peas under mattresses.
However, I'm actually posting to see if anyone knows how to get hold of item number 12 in the schematic? I need four for both sides of the car as the compartments just fall out now.
Thanks!
hamster99
Unread post by hamster99 »
I'm sure I read somewhere that the springs can be opened up so that the door bins stay put when the door is closed hard.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Rawce
Yeah, I tried that. It's kinda the reason I need new ones! I used my heavy duty pliers instead of my 81s.
x 1981
Unread post by Stickyfinger »
I have a pair.....
Rawce wrote: I'm actually posting to see if anyone knows how to get hold of item number 12 in the schematic? I need four for both sides of the car as the compartments just fall out now. Thanks!
Rawce
I might be interested in buying them, thanks.
jamescarruthers
x 47
Unread post by jamescarruthers »
I’m going to need an passenger interior front door handle for my sister’s 2001 C5 estate. Can anyone tell me the number, please? And also of the clips for the door trim which I read on another post can break.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 6954
Ok, so got your glasses on?
It will be easier for you to pick the numbers of the parts you need and then I can get you the part number.
Click or Tap Image to Zoom
jamescarruthers
x 47
Many thanks.
I believe it is No. 16, the interior door handle.
Is there a different diagram for the door card? I think I should buy the clips as a back up too.
1987 Volvo 480 ES
x 6954
Item (16) is part: 9143H7 for the left hand side James. £81.18 inc. VAT from Citroen.
This is for a standard door card if it is just the clips (70) as for anything else I'll need the VIN due to finish differences.
The clips (70) are part: 6991S6 and are 14p each.
moizeau
x 429
Unread post by moizeau »
Just like to add, but a trim tool, few quid and saves loads of grief. Something like this https://www.autozone.com/test-scan-and- ... mover-tool
Pete
jamescarruthers
x 47
Great, thanks very much thanks.
Price seems to have doubled since it was first mentioned in this topic. I guess as stock goes down they put the price up.
Second hand seems tempting again now!
1987 Volvo 480 ES
Michel
Unread post by Michel »
“ Can you believe it?!!!! C5 door handle snapped off”..
There’s a few sayings that work in reply, regarding bear’s toilet habits or the pope’s religion..
