Brakes not releasing
smoker
Unread post by smoker »
Xsara 110hdi estate, 52 reg. Had the car for a few months and notice that an advisory from the last MOT was the front brakes not releasing properly - with a number of 25% next to the advisory tho' not sure exactly what this means.
Also, whilst on a stop start run the other day, I noticed the brakes binding - e.g. car wouldn't roll down a hill where it normally would. Can't say which wheel(s) at fault, but all seemed well once cooled down. I'm guessing this could be a caliper related issue, but could it instead be master cylinder or ABS related? If calipers, can they be rebuilt (new pistons/seals) or are descent refurbished calipers available and the preferred way forward?
Any advice appreciated - MOT due April and need to get sorted by then.
Cheers
52 reg Xsara 110 hdi
x 1240
Re: Brakes not releasing
Unread post by Peter.N. »
I think you were probably right the first time and the calipers are sticking. I you pull back the rubber seals and squirt some brake fluid in behind them and can work them backwards and forwards they should ease off. You really need to take the pads out and put a tyre lever or something similar between the disc and caliper, if you can push it back even a little then press gently on the brake pedal to move it forwards, do this a few times squirting more brake fluid in each time and it should loosen up. Only remove one pad at a time and always keep something between the caliper and disc, otherwise the piston may come right out and jam.
x 94
Unread post by citronut »
the other cause of this can be the flexi hose/s collapsing internally, this can act as a valve allowing fluid through one way,
trouble with this whilst it is causing the pads to stay in contact with the discs longer than they should, it will cause the calipers/discs to over heat,
if/when you try Peter.N's suggestion of pushing the pistons back, if they are very difficult to push in try opening the bleed nipple, if the piston then retracts easily it will prove the flexi is at fault
also check out for seal kits/calipers/brake components
http://www.biggred.co.uk/index.php" onclick="window.open(this.href);return false;
they are extremely helpful and do get back to you if they say they will, even out of business hours
Regards, malcolm.
old-un77
Unread post by old-un77 »
My old Renault ('91) 19 disks front, drums rear..........had a rear brake shoe problem, when reversing after being overnight parked up, releasing the handbrake, there was a sometimes a click .
and all was well........
if driving forwards straight away instead the shoe, drum and cylinder would overheat until there were NO brakes at all...
this occurred twice, once nearly fatally, until it was noticed that the rear brake was smoking....and the click (sticking shoe)was connected to the brakes problem
it never happened to me,while I had the car as I always reversed from my garage, but after my daughter took on the car, she often drove forwards from her drive......
the first time her garage thought it was a cylinder head problem...........???? and did the head gasket job.££££
..when it occurred the second time they noticed the smokey brake, and wanted to charge her again to do the brakes....she doesn't use that garage any more....
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Check the handbrake cable outers where they curve around the strut, they can break and cause dragging, also check caliper sliding pins are moving easily(needs pad removal for this) and lubricate pistons, I like to pull back the handbrake mechanism rubber cover and lubricate with an oil/grease mixture too.
x 94
Stewart(oily) wrote: Check the handbrake cable outers where they curve around the strut,
they'd have to be very long hand brake cables Stewart :yikes: :o #-o :-D :lol: :rofl2: :rofl2: , as this being a Xsara the H/B is on the rear wheels
Regards, malcolm.
Stewart(oily)
x 35
Xantias on the brain, thats me :)
smoker
Great thoughts and links, many thanks. I have bought new discs and pads so will have a set-to in the near future. Never thoughts about trying to lubricate sticky pistions (always assumed they would be lubricated by fluid in the system) so definately worth a try. I've wondered about replacing the flexies as a matter of course (>14 yrs) but don't like the look of the connection to the metal pipe. Maybe if I'm feeling brave...
Thx again.
x 94
smoker wrote: I have bought new discs and pads so will have a set-to in the near future.
i would not fit new discs and pads till you sort the binding problem out, as brakes binding can and will cause warped discs then these will be scrap,
smoker wrote: Never thoughts about trying to lubricate sticky pistions (always assumed they would be lubricated by fluid in the system) so definately worth a try.
if the pistons are sticking it can be caused by the rubber boot between the caliper body and the outer edge of the piston not holding the dirt and water out,
so in this case it will be sticking on the outside of the main pressure seal,
the other cause of sticking pistons can be if there were another fault causing the pistons/calipers to over heat, in this case the seals tend to swell up, causing the piston to be very very tight,
Regards, malcolm.
x 1056
Unread post by wheeler »
A brilliant device for investigating sticking brake problems are non contact thermometers like this one > http://m.ebay.co.uk/itm/361135003818?nav=SEARCH" onclick="window.open(this.href);return false;
Take the car for a drive then stop & you can instantly measure the temperature of the brakes, you can then pinpoint which corner is sticking. They also have loads of other automotive uses & its something my toolbox would never be without now.
x 694
Unread post by Mandrake »
Hi wheeler - can you confirm the model of IR thermometer you bought and approximate cost ? Your link goes to a sale that has ended which shows a lot of similar suggestions of various prices but they're all slightly different models etc..
I've wanted one of these gun style IR thermometers for a long time, didn't realise they were so cheap now! Definitely one for the Christmas sock. :)
I have a suspicion my front brakes might be intermittently binding just enough to cause problems - a couple of times I've noticed a burning brake smell after moderate driving and the handbrake cable feels a bit seized in operation...(it pulls tight unusually quickly)
