Car won't start!
Jaggiethistle
Re: Car won't start!
Unread post by Jaggiethistle »
Sorry for dragging this out fellas but after checking again (late last night when the road was quiet) it seems the lift pump is priming! :roll: Do I go for the camshaft/ crankshaft sensors as Hamster posted ( where are they??)!
darbuck
x 290
Unread post by darbuck »
If its the same hdi unit as the c5 the cam sensor is at the rear centre of the upper timing belt cover
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
hamster99
Unread post by hamster99 »
I think from memory the crankshaft sensor is in the 10 o'clock position when you look straight at the crankshaft pulley.
Bear in mind that you will only be able to check the connectors are plugged in or not. You will need to use a lexia to determine if they are working. It will give you an error code to tell you.
Where are you based? There might be a member with a lexia who would be willing to help out.
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Jaggiethistle
Cheers Rob
Will check the connectors soon as. Live in Ayrshire m8.
Jaggiethistle
just been out to check and can't see any connectors around the cam belt area Rob?? Excuse the ignorance here but is there a way to check whether fuel is getting to the rail so that I can eliminate the pump question? as the lift pump seem to me like it's energising when the key is turned to the second position.
x 1477
Whereabouts in Ayrshire? Mandrake, DHallworth and I are not a million miles away. I'd offer, but flat out up to Christmas so can't come out to it - if it was mobile I could plug it in at mine :rofl2:
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The pump/sender units seem to look the same whether theres a pump in there or not, I took a couple out in the breakers and the non pump jobs appear to have a place for the pump, though comparing the electrical connectors might give a clue, I used a hammer and screwdriver to tap the locking ring around and it undid easily. I think HDI 110 motors with bosch injection have them. so plenty of potential donors out there.
