Turbo whoosh
darbuck
x 290
Turbo whoosh
Unread post by darbuck »
Hi lads car started whooshing last night on the way home 03 c5 2.0hdi would it bearings or loose or broken pipe help
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
Northern_Mike
Re: Turbo whoosh
darbuck wrote:Hi lads car started whooshing last night on the way home 03 c5 2.0hdi would it bearings or loose or broken pipe help
Probably a split pipe. Check the big rubber one the comes from behind the engine over the top and to the intercooler in front of the radiator...
x 1240
Re: Turbo whoosh
Unread post by Peter.N. »
..or could have come off the turbo.
darbuck
x 290
Re: Turbo whoosh
will do lads thanks for replies i was afrsid it might be kaput turbo do they give much trouble on the 1st generation hdi
Darren
Northern_Mike
Re: Turbo whoosh
darbuck wrote:will do lads thanks for replies i was afrsid it might be kaput turbo do they give much trouble on the 1st generation hdi
No, not that I'm aware. They're not under much stress and there's no problem with the oil system. It'll likely be a split pipe, but check the parts of the pipe you can't see - i.e. the underneath, as this is where my Xantia had split and it wasn't obvious at first. I looked everywhere, including getting under it and checking the pipes on the turbo. It was split on top of the engine, but on the underside of the pipe. It sounded very obvious when it whooshed - like someone was operating a massive fan behind the dashboard
darbuck
x 290
Re: Turbo whoosh
Sounds exactly like what im hearing from mine ill have to have a look around tomorrow
Darren
x 1240
Re: Turbo whoosh
I've got two, one in a 406 with 231,000 miles on it and another on a C5 with 200,000 practically all original.
darbuck
x 290
Re: Turbo whoosh
The engine has 100000 on it I replaced it last summer but the turbo has 187000 on it as new engine was bare
Darren
