O-Rings for hydraulic pump, Citroen Xantia
Brianszens
Unread post by Brianszens »
Does any know where I can get O-rings for the hydraulic pump for a Xantia Estate?
Also is it a special type of O-ring, or an standard one?
x 695
Re: O-Rings for hydraulic pump, Citroen Xantia
Unread post by Mandrake »
They should still be available from Citroen - there are two types, small green ones and larger black ones, for the two different sets of pistons. (steering and suspension) You need 6 of one and 2 of the other. I don't remember off hand which ones are which, and don't have the part numbers but I'm sure someone will be along with those soon...
There is also a large o-ring behind the triangular plate that holds the pulley on - this o-ring is NOT available or even listed, however if leaking it can be replaced by a green square section seal intended for a suspension sphere neck! (I've done this before, so I know it fits and seals properly...)
Are you wanting seals because of a leak ? Have you positively identified where the leak is from ? There are a number of different places on the pump that can leak.
Xaccers
x 188
Unread post by Xaccers »
Normal/common leaks from the pump are from the large hex that the metal pipe comes out of, this takes an o-ring available from Citroen for under a quid and is dead easy to replace. It would be worth replacing the identical seal on the blank large hex. There's a non tensioned spring under the large hexes so careful they don't drop out.
The seal between the main pump body and the bell end which feeds the power steering can also leak. This large o-ring is still available from Citroen, gain for less than a quid (or just over), but it's a pump off job and a vice comes in handy to hold the pump body while you gently ease off the bell end which is held on by three bolts accessed through the holes in the pulley. Use the bolts to help pull the bell end back on tightening each one in turn a bit to keep it straight.
The torx piston caps rarely if ever leak.
DIY sphere tool
Brianszens
Identified leak on the pump, it would be the black ring, if I can get them from citroen, I will give it a go. Thanks for the advice.
x 8370
O ring part numbers...
Item 5 is the delivery union O ring and Item 4 the piston (Torx) head O ring...
charentejohn
Unread post by charentejohn »
Just done this replacing seal 5 in the diagram as there was a steady leak. I think it is fixed but just want to check I did it right, when dismantled there was no sign of an old O ring.
No dealers near me so I bought some rubber seals for plumbing, they were 16mm internal dia (too big) and next size just too small but did fit.
I removed the threaded bit and it had a groove in the end with some sharp bits, looked like it might have taken an o ring but not sure. The larger ring was too big but I put the smaller one in, even though it didn't touch the sides. There seemed to be a groove in the base of the pump which may have taken a correctly sized O ring.
So all refitted and no leaks so far, do you think this will hold as the ring must be clamped between the two flat surfaces of the fitting and the pump. If the exact size is important then I will redo it, I think there are a couple of knuckes I didn't skin putting it back. Or is it a case of leaving well alone and buying a correct ring manyana ?
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
x 3306
The problem with a normal rubber seal is that the LHM will eat it over time.
charentejohn
Ah, I will get a real one from the dealer next time I am there which could be a couple of weeks or so.
The original one was either never there or dissolved completely :)
charentejohn
Still a slight leak and needed LHM (Stop kept coming on) so redid it. Sadly the O ring has been shredded and presumably now in bits in my hydralic system.....
Just redone using PTFE tape on the threads and no O ring. So far so good still to confirm the system hasn't been damaged by the shredded seal, only time will tell ?
Still trying to decide if it is sell or fix as car has been unreliable for a few months now, this is just the latest. I thought all was sorted.
x 695
I can't see PTFE tape lasting long - those two o-rings in particular are under a lot of strain and even the original types are prone to leak, for example when the accumulator sphere is left to go flat.
Is it really that hard to get the correct o-rings from Citroen and fit them ? It's not really fair to say the car is unreliable when it's had the wrong o-rings fitted previously (both by you and by the looks of it a previous owner) and now has PTFE tape in place of a high pressure o-ring ? :roll: That will certainly not add to its reliability...
Reading one of your previous posts again I think you might be confused about where the o-ring actually goes ? On the two large plugs (hex head not the torx head ones) there is a groove half way up the plug just past the threaded section where a large o-ring fits. You have to carefully roll the o-ring from the bottom up over the threads to get it into place. There is no other o-ring for those plugs. It sounds to me almost as if you're trying to fit a smaller o-ring down underneath the plug ??
charentejohn
Darn it, or words to that effect.
I have just topped up with 1L of LHM which will all end up on the floor when I do this again. Sadly I think the O rings I have will fit if slid up the plug, 16mm internal diameter.
I did think the bit at the bottom would not hold an O ring as sharp edges.
Strange there is no O ring at all on it. I will remove the shield under the engine before trying again as it currently has about 1L of LHM soaked into it, and the garage floor. I will put something to catch it this time.
Reliability is a big issue here as it is possible to drive for hours and not see another car. I do have recovery but they will take it to the nearest approved garage. Last time on a Transit with duff starter motor I was charged 100 Euros labour and 700 Euros for an exchange starter, on a van worth 800 Euros. I could have bought the starter myself for 200 Euros online but as it was 100 miles from home I had no choice. I had another part replaced by a local garage, I bought it for 100 Euros, garage price (they laughed at it themselves) 380 Euros + tax. Hence my needing someting that works and can at least limp home.
charentejohn
Did this yesterday, wore my glasses this time, so what I thought was a solid top to the plug was also a rubber ring crushed into a flat edge. Looked to be all one piece and took a stanley knife to get it off.
Fitted the O ring I had and it fits perfectly, so far no leaks. The old one was so soild that stuff was seeping past.
Managed not to lose the LHM by clamping the incoming hose so hardly lost any, wish I had thought of that earlier....
Hopefully all the bits from the misused O ring will end up in the filter at some point and not jamming the hydraulics.
x 695
Excellent. Lets hope it holds this time!
x 3306
You live and learn. If the 0 ring was normal rubber it should rot down and not cause any problems, and any fragments should be caught by the filters in the LHM reservoir.
x 94
Unread post by citronut »
charentejohn wrote: Hopefully all the bits from the misused O ring will end up in the filter at some point and not jamming the hydraulics.
i dont think it will as by the time the citro blood goes through the pump it is way past the filters,
it will probably end up in the steering pinion, the pump workings and or the regulator
Regards, malcolm.
