Xantia stolen - how did they bypass immobiliser?
taffy
Re: Xantia stolen - how did they bypass immobiliser?
wish i knew how to nick me own car at the mo lmao!
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
dnsey
- x 19
Interesting to say the least that the OP (with the same username
) asked the same question on another forum several months ago, except that his dad's car was then a Xsara!
KP
- x 27
Sorry to bring a thread back from the dead but I may have been a complete numpty and forgot his pin code in his Activa
Car has been parked up for a month and I've had another car with a keypad in the interim so I think I'm stuffed!!!!
Is there anyone with an ecu with a known code or anyone know of a service that will delete the bloody thing from the ecu if I send it off to them at all?
KP
- x 27
Thank foook for that I've found it!!
- x 695
If it was easy to bypass it wouldn't be a very good immobiliser now would it ?
KP
- x 27
Every other model of Xantia fitted with one can be resolved very easily but the tct is the only issue one...
There must be a simpler way for this engine... Maybe dickieg knows a way as he aluded to previously and let's face it, how many of us still have the keypad if we can get rid of it?
- x 695
I do...
KP
- x 27
Everyone I have I replace the sodding things with oddment trays as they do nothing but cause annoyance. Do you really enjoy putting the code in everytime you want to use the car...
- x 695
No, I just don't have an oddment tray to replace it yet
KP
- x 27
Paul probably has a few and I bet David had one as well
- x 8349
Thanks goodness for that WillKP wrote:Thank foook for that I've found it!!
Indeed, the TCT is the only one in my experience where the keypad cannot be rendered inoperative in the usual way... I do not know why this is...KP wrote:Every other model of Xantia fitted with one can be resolved very easily but the tct is the only issue one...
Bx gti turbo
Jim I've been trying to find a way of contacting you I haven't been on these forums before soo hope this works. I've 2.0 swapped my bx gti xu10j2te Citroen xaintia activa 2.0 turbo and am struggling to get the thing to fire as far as I'm aware I have wired the double relay correctly and also permant live to the ecu correctly. The only reason I can think that the car won't fire is because the emobilzor or the keypad is there a way of manually overcoming this or does this have to be coded out (unlocked) I'm really struggling finding someone to unlock one of these ecus do you have any idear who may be able to help.CitroJim wrote: 09 Jan 2013, 16:34 Was it a diesel or a petrol and more specifically, what engine?
Generally it is very difficult to bypass a keypad and on a diesel, given the pump armouring is intact, very difficult and for the purposes of nicking same, almost impossible...
On a petrol, the easiest would be to go equipped with a spare ECU for which the code is known. That would take planning and most thieves aren't that bright generally...
It must have been well worth the trouble of nicking it...
Cheers in advance (Harley Cross)
- x 1449
There is almost no way to bypass the ECU immobiliser on a locked ECU, other than by reprogramming the ECU.
If you know the immobiliser code which was last set in the ECU, you could fit a keypad (I am assuming that it was a S1 Xantia, S2 have a key transponder immobiliser).
There are devices available on the grey market which will scan the ECU and try all the possible codes until the correct one is found, but you would still need to fit a keypad to start the engine.
All UK Xantias from 1995 were fitted with immobilisers, in some other markets (especially outside Europe) immobilisers were not fitted, and the ECU did not have an immobiliser function.
Bx gti turbo
xantia_v6 wrote: 19 Apr 2020, 21:24 There is almost no way to bypass the ECU immobiliser on a locked ECU, other than by reprogramming the ECU.
I am unsure if the engine was from a s1 or s2 I am guessing a s2 from how the loom is surly there is somebody out there that could (chip change) wipe the imbolizer from the ecu
I have seen you can buy unlocked ecus for xaintias /406 ect it must be able to be done as alot of the 205 Bois have done the conversion.
KP
- x 27
There are ECU reprogramming companies out there that will wipe the immob part of the ECU out but it would be around £250 last I asked one about this.
