misbehaving suspension
froggy
- (Donor 2026)
- x 4
H imy S2 Xantia, the rear suspension of the car will not stay in the middle position.When doing Citroen robics, the front of the car will move happily through the three positions, but the rear will only move low to high or visa versa, not reconising the middle position. anybody got any idea? cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 3296
Re: misbehaving suspension
I would raise her to full height, support her so she cannot drop (especially as the suspension is playing up; if you don't, and she drops, she WILL kill you!), and to check the linkages and mechanism at the back. It could be due to accumulated dirt causing the height corrector linkages to bind (apparently the height correctors themselves rarely fail). I am not sure about this, but it could also be because the dog bone has failed or come off (a plastic connector that links the anti roll bar to the height corrector linkages), or the clamp has failed on the anti roll bar.
I AM NOT KIDDING ABOUT THE NEED TO SUPPORT THE CAR BEFORE GOING UNDERNEATH HER, ESPECIALLY WITH SUSPECT SUSPENSION!! SHE MUST NOT BE ABLE TO DROP, SO USE GOOD SUPPORTS (AND THIS DOES NOT MEAN JACKS!).
- x 5673
Agree with James, from experience, that it is most likely to be a dog_bone failure or that as in my case, the 'hook' for it on the ARB has rusted awayfroggy wrote:H imy S2 Xantia, the rear suspension of the car will not stay in the middle position.When doing Citroen robics, the front of the car will move happily through the three positions, but the rear will only move low to high or visa versa, not reconising the middle position. anybody got any idea? cheers Terry.
- x 695
Yep, dog bone link or the roll bar clamp link.
