So my dad's getting a 1993 petrol ax in white. For his birthday! Think it's 1.2l, she's done 180,000kms.
The check engine light is on apparently, so if I buy a Lexia now that we have 2 Citroens in the family, will I need a particular adaptor?
Besides the normal service stuff is there anything to check?
It nearly didn't happen cos the paperwork made my dad cross. You have to have townhall certified copies of things and then go with the seller to a solicitor. Madness!
Looking forward to a race with Fred. Smirk!
New ax
Re: New ax
Same story for 1993 AX.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49856
The information available from many of the earlier ECUs is limited. I'm not sure if the lexia will do much for you. Perhaps someone who has actually used one on an early 1990s model can fill us in on that.
Re: New ax
Ok thanks. Looks like a sweet little car, tidy too.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Re: New ax
The main trouble I had with mine was a worn TPS on the throttle body, it was otherwise fine, my favourite part was the wine bottle holders in the doors, but try to avoid having an accident as they have a low occupant survival rate!
Lexia ponce
Lexia ponce
Re: New ax
1.2? Should be 1.1 or 1.4. The engine light is quite likely triggered by the throttle valve potentiometer. Which can be taken apart and cleaned.
'73 DS 23 pallas, '87 CX25TRD2 long, '11 C5 HDi 165 Tourer exclusive
Re: New ax
She has been named "Gwin".
Yes you're right she is 1.1l. Goes up the hill better than my Fred. Sigh.
Would the TPS or TVP affect a slight occasional stutter? It's not noticeable as a passenger. The engine management light went off after a battery reset, but has come on again.
Will try not to have any crashes!
Re: New ax
Stuttering is a sure fire sign of TPS/TVP wear.
Lexia ponce
Lexia ponce
- Skull
- My Cars: Citroën Xantia XII HDi
Citroën sAXo XII
Missing AX 1.4D Echo - x 225
Re: New ax
Got excited then I thought they'd started remaking them
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
Gone
