shear bolt removal tool
- x 94
dose anyone ( Sir Jim ) know were i can get a shear bolt removal tool????
Regards, malcolm.
OnlineHell Razor5543
- x 3298
Re: shear bolt removal tool
If you get one I may have need of it, as Gracie has sheared one bolt holding her O/S/R heat shield on, and a second trying to follow it!
Don't know how good they are;
http://www.ebay.co.uk/itm/5PC-SCREW-BOL ... 58aab2c991" onclick="window.open(this.href);return false;
- x 94
thanks for the input James but im talking the bolts that there head are intended to shear on fitting "shear bolts" ( diesel pump imobaliser armour type of thing ), you are then left with a tapered head i usually drift these undone with a center punch, when/if you can get near enough to the little BBBBBBB's
Regards, malcolm.
DickieG
- Monaco's youngest playboy
- x 33
It's called a drillcitronut wrote:dose anyone ( Sir Jim ) know were i can get a shear bolt removal tool????
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8448
Malcolm, what you need is a set of inverse flute sockets
Try a set of these babies
Others are available...
I have a set and they work well...
That works a treat too Richard, especial when the above won't fit due to space and access issues...DickieG wrote:It's called a drillcitronut wrote:dose anyone ( Sir Jim ) know were i can get a shear bolt removal tool????
darbuck
- x 289
Hows it going lads I snapped an engine head bolt a few years back needless to say panick anyway got a set of stud extractors you have to drill a hole in the bolt the reverse thread catches the bolt and pulls it back out you need agood
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
darbuck
- x 289
You'll need a good engineering supplies or ebay
Darren
- x 94
ok thanks for all the input,
but this time i resorted to a 4.5 inch angel grinder with a very worn/small diameter cutting disc,an air cut of grinder, a center punch, a small chisel and an ammer,
this operation was performed on a Preg NA diesel ZX with a Bosch pump,
and Jim
i firstly removed all the injector pipes and sealed all the pump outlet and injector inlets with gaffer tape
i should have it all back together and running tomorrow
and Jim
Regards, malcolm.
darbuck
- x 289
Your a braver man than i
Darren
- x 94
this is my second one down now, as a few years back i did this to my old R reg XANTdarbuck wrote:Your a braver man than i
Regards, malcolm.
- x 8448
Well done Malcolm!
And I!!!darbuck wrote:Your a braver man than i
- x 3298
Well, if you need to use them next time I am with you, Malcolm, I have got some of those stud extractors I linked to.
