Sorry for this but I wonder if any one can help me on this wee problem [:(].
Wifes Car is a 2001 Renault Megane 1.6 16 Valve Convertible with vented disc's and Reno / Lucas calipers.
I need to change the front pads. No big problem but I am at a loss on how to push the caliper pistons back in. The vehicle has ABS and I seem to remember that you have to open a bleed nipple or some thing. I'm un willing to just push them back as the I know you can damage the ABS. Any Info greatly appreciated [:D].
How do I do this then?
- x 1449
To avoid damaging the ABS valve block it is recommended that you open the caliper bleed nipple when pushing the piston back, so that you push the fluid out of the nipple rather than back through the ABS gubbins. Don't forget to go careful with the nipple, top up the fluid and bleed the brakes on completion!
VisaGTi16v
Stuart McB
