All Things V6...
DHallworth
- x 161
Re: David Hallworth's Blog aka All Things V6!
A friend of mine is an MOT tester, but as he's just gone self employed he's not set himself up as a station yet, so come MOT time I'll get him to give it a once over for me and see what it's like. If it'll pass another MOT without much work then it'll get one, if it won't then I'll decided what to do nearer the time.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8411
Out of interest David, what were the advisories at the last MOT?
DHallworth
- x 161
Mainly rust, rust and more rust, Jim.
I'll dig the MOT out tomorrow and will list the exact ones.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8411
Normal XM stuff then David
Such a shame...
It's a V6 so really needs to be saved if at all possible. Can't be many left at all now...
Such a shame...
DHallworth
- x 161
I've been speaking to someone about this and I reckon that it might be able to live on after it's MOT is due.
Time will tell I guess. Will posts up a picture of the advisories later for sure.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8411
Excellent
That's good news David...
DHallworth
- x 161
As promised...
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
citroenxm
- Fallen Hero
- x 70
Nothing out the ordinary there.. not bad for a series two body. Gone in all the useual places..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8411
Absolutelycitroenxm wrote:Nothing out the ordinary there.. not bad for a series two body. Gone in all the useual places..
Rear brake pipes are a rotten job though. Done one. Horrid
'Slightly' would infer they're not seriously bad perhaps?
citroenxm
- Fallen Hero
- x 70
possibly.. useually a rub with emmery and a clean up and paint with proper underseal could see them live on!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8411
One hopes Paul, one hopes...citroenxm wrote:possibly.. useually a rub with emmery and a clean up and paint with proper underseal could see them live on!
DHallworth
- x 161
Well once I get some other bits and pieces done I'll be getting her up in the air and getting a look underneath.
The suspension on it is rock hard yet there's no errors showing on the hydractive ecu. I'm reasonably sure that it's the electrovalve leaking, but it's odd that there's no faults stored.
Does anyone know if a Xantia electrovalve will fit it?
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8411
Electrovales will only produce a fault if they look electrically unhappy David.. Yours are clearly quite content in that respect...
Yes, a Xantia one will fit.
Can you hear them humming in soft mode?
Are the spheres OK?
Are the spheres OK?
citroenxm
- Fallen Hero
- x 70
If spheres are simply flat that will be your suspension issue with no ecu errors..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 695
It's far more likely the hydractive centre/regulator spheres are completely punctured. You can throw a couple of spare accumulator spheres on in their place as a quick test!
As Jim says unless the electrovalve is electrically faulty it won't log a fault code. Even a high resistance coil won't trigger it unless its really high - normal resistance is 3.3 ohms but the ECU is "happy" even with as high as 100 ohms or so...
