Citroen Automatic Gearbox fault
addo
- Sara Watson's Stalker
- x 95
- x 3283
Re: Citroen Automatic Gearbox fault
Tom, if you can get your daughter to give you the VIN umber, and then post it up here, members with the relevant access will be able to see what the C8 had when it rolled off the production line (and this includes what model of gearbox).
tomthered
Thanks for all the info guys really helpful. Will find out tomorrow and come back to you
EDIT Just been told three of the codes were
P0380
P1345
P1519
The oil leak is coming from the main engine seal area, which is obstructed by the gearbox, so he cannot see where its coming from. The guy who did the cambelt told her this needed replacing to stop the leak so I assume there is some form of gasket between engine and gearbox, but don't know as am not a mechanic.
P0380
P1345
P1519
- x 3283
Does the sliding door have brass plungers on it that contact brass plates? Is so, it could be work giving the brasswork a good polish, as sometimes a poor connection here will affect the door electrics.
tomthered
Will have a look at the door over next day or so HellRazor.
EDIT @Addo I cannot believe that a little round thing like that Solenoid valve could cause an Automatic Gearbox Fault!!
FURTHER EDIT The Vin from V5 logbook is VF7**************[VIN obfuscated, can be read by forum staff] Hope this helps determine if its AM6 or AL4 gearbox
addo
- x 95
It's an AL4 auto. The fault codes cited all relate to the engine, and reflect likely use of a non-genuine scanning tool.
The solenoids are a common problem, they buzz at 100 cycles per second to control the hydraulic pressure (of your transmission fluid). The internal clearances are microscopic; too small in fact. With wear to metal parts of the transmission, the energised coils inside the solenoids act like magnets and attract/trap the superfine steel powder, making the solenoid "sticky".
Replacement by a competent indy is not hard, if they're quick it should be under two hours labour. Also have the transmission's own ECU software scanned to make sure it is the most up-to-date version.
tomthered
That sounds a lot better price wise. Am just waiting for a member to offer the use of a Lexia and I will put the codes up as soon as I get them and thank you all for your help up to now.
- x 8252
Tom, I asked for a smell of the oil from the leak to try and determine if it's from the engine or the gearbox. Autoboxes rarely leak but there is an oil seal behind the torque converter that could possibly leak..
By smell it should be quite easy to differentiate the source of this leak. Gearbox oil always smells horrible and nothing like engine oil.
How bad is the leak? To fix it may well involve the removal of the gearbox unless the leak is from well above and the exit point f it is being seen rather than the source.
- x 694
Does the AL4 have a banjo joint behind the left hand wheel arch liner that could leak like the 4HP20 ?
- x 8252
Not as far as I know Simon but that's good point as I'm sure it'll have connections for a cooler somewhere about its person..Mandrake wrote:Does the AL4 have a banjo joint behind the left hand wheel arch liner that could leak like the 4HP20 ?
Worth checking around the 'box for leaks too as where the leak appears is usually a way away from the source..
addo
- x 95
- x 8252
That happens with the HP20 too Adam...
tomthered
Jim I will try and have a look myself this weekend and see if I can smell the oil myself. If the gearbox has to be removed to fix the seal or oil leak I assume thats a time consuming exercise?
addo
- x 95
tomthered
Have tried messaging several members for help with the Lexia diagnosis but it keeps saying the member is no longer available, despite them having posted in October 2014!! I have tried Handyman as I have been trying to get hold of his brother, cook in fat, in St helens near to us. I have also tried Robert12 and chlorate but no joy with any. Can anyone suggest how to get hold of them please?
