Yet another adventure....... Peugeot 407 GT Coupe
Trainman
(Donor 2018)
x 43
Re: Yet another adventure....... Peugeot 407 GT Coupe
Unread post by Trainman »
Here's the proof of the faulty coil pack:
I've had a look this afternoon and got them ordered for tomorrow, lets hope it doesn't rain
Steve
http://c6owners.org/index.php
KP
x 27
Unread post by KP »
Fingers crossed you get the part tomorrow Stephen. I'd maybe heed Mr H's advice and do the rear lot in one go for the cost of it :)
Trainman
(Donor 2018)
x 43
I am Will, although that itself has caused me problems. I've managed to get Delphi ones at £25 each, but nobody has 3 in stock, so trip to St Helens for 2 and the last one at Preston. Directorate at Warrington don't have any at all.
Steve
Trainman
(Donor 2018)
x 43
I managed to get the fault coil pack out but can't get the replacement to sit right, purely because I can't shift the inlet manifold far enough out of the way, so trying to be clever, I moved a good one from the front bank to the rear to replace the dodgy one.
However, given my current luck, I've managed to snap the ex front coil pack, half way up, so there is now 1 part in the engine and the top half somewhere in the garage after I chucked it in disgust........
I've given up for today (bad light stopped play) as they in cricket....... I need to work out a way of being able to move the inlet manifold without disturbing the gas, could do with some "girlie" hands instead on the shovels I have :wink:
It's actually a fairly easy process to replace the coil packs, once I work out how to get the necessary room.... for my paws.... :roll:
Steve
DHallworth
x 163
Unread post by DHallworth »
Ahhhh... That's a bugger with the LPG. Usually the inlet just lifts right off!
Hopefully you'll get it sorted tomorrow mate. Maybe Will has tiny hands that match his height... Might be worth a call :rofl2:
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Trainman
(Donor 2018)
x 43
She done, faults cleared and road tested, something good at last. :lol:
I replaced another front one into number 6, and then put a new one at the front. I think that when the back one goes again, it can go back to the garage and I'll pay them to faff about with it. :roll:
Anyway, off for tea, before updating the Xantia blog........
Steve
x 8213
Excellent news Steve :-D
I trust what you're going to write in the Xantia blog is good too [-o<
Trainman
(Donor 2018)
x 43
Well, it will certainly be of interest....
Steve
x 8213
Trainman wrote:Well, it will certainly be of interest....
It most certainly is Steve...
Trainman
(Donor 2018)
x 43
I noticed last night and again this morning that she seems to be 'sucking' air from somewhere, almost like there's something not connected :roll: but I know I reconnected everything #-o she's running great though so it could just be me listening for something out of the ordinary :roll:
maybe I'm getting paranoid.......... :cry:
Steve
x 8213
No it's not Steve,
That's a perfectly normal reaction following having done lots of work around the engine. Your senses become heightened...
You should see what I'm like :rofl2:
It'll be just a bit of induction roar...
But you will check all the hoses again, just to be sure...
Trainman
(Donor 2018)
x 43
CitroJim wrote:No it's not Steve,
With the luck I'm having at the moment....... nothing surprises me anymore..... :roll:
CitroJim wrote:You should see what I'm like :rofl2:
er...... thanks for the offer, but I'm going to decline....... :rofl2:
CitroJim wrote:It'll be just a bit of induction roar...
If I check anymore, I'll wear the screws out on the jubilee clips :roll:
Steve
x 694
Unread post by Mandrake »
You didn't forget to attach the air hose to the ICV did you ? I'm assuming the ES9J4S has a separate smaller hose from the air filter box to the idle control valve like the ES9J4 does...
Leaving that hose off wouldn't affect the running in any way (except it would draw in a small amount of dirty, un-filtered air) but it would certainly make a sucking noise!
What about the vacuum hose for the fuel pressure regulator ?
Trainman
(Donor 2018)
x 43
Morning Simon, all the hoses are attached, I checked, double and triple checked last night. The thing is I don't recall it making the noise, but it's been a while since I've had the bonnet up, and I was trying to it yesterday been the showers, I'll have a look later, this afternoon when I get home.
By the way, first job on this is exactly the same as the Xantia, air filter off......
Steve
Trainman
(Donor 2018)
x 43
Right then, here's the gas figures for somebody to work out:
62.75 litres @ 65.9 pence per litre mileage covered 304.2
Steve
