406
Mbryn1
406
Unread post by Mbryn1 »
any advice on removing high pressure pump 2001 406 2.0 hdi
Thank you Bryn
x 1240
Re: 406
Unread post by Peter.N. »
You have to remove the timing belt first than I think its held on by three bolts. Are you sure the pump is faulty and its not the pressure regulator?
x 1240
Re: 406
Are we talking about an Hdi or XUD engine?
Ignore this, I can't read.
x 3306
Re: 406
OP says 2.0 HDi.
x 1240
Re: 406
Yes I just noticed, another senior moment.
Mbryn1
Re: 406
Yes pump broken got fillings in fuel filter
x 3306
Re: 406
I believe that the HP pump is AFTER the fuel filter, so fillings in the filter are more likely to be the in tank lift pump.
Mbryn1
Re: 406
Lift pump tested at garage all ok he put some clear tubes on injectors they are all good no leaks anywhere
x 1240
Re: 406
Leakage isn't the problem, the pump disintegrates, if there are filings in the filter the lift pump needs replacing. I had this problem with mine and what finally showed up was filings in the fuel pressure regulator on the HP pump which blocked it and caused all manner of engine problems. I thought it was the pump and changed it but when I subsequently fitted the old regulator all the problems returned.
Mbryn1
Re: 406
So should I scrap it
x 3306
Re: 406
The fuel pump shouldn't be that expensive, or difficult to replace. I think this is what you are looking for;
http://www.ebay.co.uk/itm/PEUGEOT-406-1 ... 43cafb2937" onclick="window.open(this.href);return false;
There are others on e-bay, that was the first one I found.
Mbryn1
Re: 406
But that pump came up with no faults
x 3306
Re: 406
The problem is where the fillings came from. The fuel starts in the tank, is moved by the lift pump, passes through a fuel cut-off, then through the filter onto the HP pump, into the common rail and then through the injectors into the cylinders (assuming I have got this right), passing through various lengths of pipework on the way. That means that you can eliminate everything after the fuel filter as a cause for the filings.
Mbryn1
Re: 406
8-) Also car ticks over perfect and will run all day but when you drive it cuts out also got anti pollution on dash
x 1240
Re: 406
The pump will still function perfectly - it just fills the fuel system with metal filings, its a well known problem.
