Citroen C5 Hdi Estate 2010, Pollen Filter Location
Bassrock
Unread post by Bassrock »
Ok lads an lassies,
Have a 2010 C5 HDI 2.0 Estate, going to change pollen filter tomorrow.
Now,
Anyone know where the pollen filter hides on this one ? :?
I knew where it hid on a 51 and 54 plate, passenger side, centre console remove panel, doddle.
x 1499
Re: Citroen C5 Hdi Estate 2010, Pollen Filter Location
Sounds like a bit of a PITA: http://www.frenchcarforum.co.uk/forum/v ... =3&t=41543" onclick="window.open(this.href);return false;
Ben82
x 7
Unread post by Ben82 »
Maybe be glad it's not a LHD.. https://mega.co.nz/#!Ao1FHZCY!BEGvoWgbR ... VB995-eFvc" onclick="window.open(this.href);return false;
My Mk1 is a pain to get to since it's LHD :)
2004 Citroen C5 3L V6 Auto
Bassrock
Thank you Richard and Ben,
Cheers.....
Looks like i'll need to get the small fingered (non swearing) contortionist in, trouble is, nil stock of those.
Oh joy......
Xantippa
x 29
Unread post by Xantippa »
It's quite easy even on LHD.
Bassrock
Ah, you'll be the small fingered (non swearing) contortionist then !
Cheers
x 5687
It is awkward but not too bad. I took about five minutes but never rush anything.
Bassrock
Hi all,
Just succeeded in putting new filter in, 95% seems to go in easily enough after bending the sodding thing to gat back in (and out!).
The other 5% was a push at the end (seemed a bit crushed up, especially at top by about 10mm), hopefully it will be fine after a few rattling miles..
Thanks again for all your help.
osx
(Donor 2022)
x 15
Unread post by osx »
Not the easiest one to get in and I am not sure after all this bending and pushing if it isn't crushed up. I guess I will find out if I have to clean the dust every day ;-)
C5 X7 Exclusive 2.0 HDi Auto
