Should note that those prices from Malcom are per pipe - there are 2 of each pipe.
Leaking injection pipe
- x 1480
Re: Leaking injection pipe
Ooops sorry
I'd clicked on the later engine without realising....
- x 94
there is also a variant on those part No.'s dependent on rp No. which i did not check under your chassis No.
Regards, malcolm.
Barry1
Thanks Malcolm, lucky I didn't order those other 2 pipes.I googled those part numbers and again only got eastern European sites I must have a funny connection LOL
Can you reccomend a garage in East Sussex I can order them from as they are bound to be cheaper in the UK than in France (the're only made here!! )
- x 94
if you read/speak frog
try checking the price's on
http://service.citroen.com/pages/index.jsp" onclick="window.open(this.href);return false;
just select the language you require of the country you which to see the price for,
should be all the same the world over, but im sure addo ( AdaM ) IN OZ says the dealer price over there is steeper than here
Regards, malcolm.
Barry1
Thanks for the help chaps I think it's sorted now I'll give her a couple of runs before I start the celebrations though.
Barry1
I tried that Citroen service but as I'm not in the motor trade I could not register.
- x 1480
Neither are the rest of us - don't let that put you off! Just make a VAT number and away you go
- x 94
there should not be any need for that, just register a private customer,RichardW wrote: Just make a VAT number and away you go
Regards, malcolm.
