David.
406 V6 Coupe
DHallworth
- x 163
Re: 406 V6 Coupe
Enjoy it
They really are rather nice cars to drive.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
bxzx16v
- x 34
Re: 406 V6 Coupe
I'm quite impressed David with the combination of ride and handling. Not as sharp as my old Zx for turn in but not bad. It's already embarrassed an audi driver who was tailgating the other day.
Mark
Mark
lexi
- x 134
Re: 406 V6 Coupe
There isn't a better looking Coupe in it's class. That looks a nice example. Get it rustproofed Mark, these have got to start climbing in price soon.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
bxzx16v
- x 34
Re: 406 V6 Coupe
I've got some Bilt Hamber stuff from when I did the Zx, I think I'll order a bit more and that should do fine. It's off the road through the winter and tucked up in the garage other than the odd run on dry days. It really is ridiculous what price you can pick one up for.
Mark
Mark
bxzx16v
- x 34
Re: 406 V6 Coupe
The coupe will be called on for daily duties for a couple of days , I need the garage for a few days to prepare two wooden doors/frames for fitting this weekend. I'm looking forward to using it for a while, as much as I like the blingo it's nice to have a change once in a while. problem is the 406 tempts you into going the longer route whenever I take it out .
Mark
Mark
Trainman
- (Donor 2018)
- x 43
Re: 406 V6 Coupe
Get LPG then it doesn't matter........
Steve
http://c6owners.org/index.php
lexi
- x 134
Re: 406 V6 Coupe
Mark: Did you build those fence panels at your house?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
bxzx16v
- x 34
Re: 406 V6 Coupe
Lexi the fence panels can be bought from any decent fencing/timber specialists, they are available in different heights and styles. Beware though if you fit them into the concrete posts with the concrete gravel boards as the panels are 1.800mm wide and require an add on piece on each side as I think the concrete gravel boards are 1820mm. Also depending on manufacturer some are screwed together and some are stapled, go for the screwed ones as the staples eventually pop out. They do matching gates too. If I did a few miles in it Steve I may have considered lpg but yearly mileage may only be around the 1500/2000 mile mark.
Mark
Mark
lexi
- x 134
Re: 406 V6 Coupe
Thanks Mark...........they caught my eye and I thought of making one. We get very little quality stuff like that up here mate.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
bxzx16v
- x 34
Re: 406 V6 Coupe
I know B&Q and maybe Wickes do the continental style panels, 1.8x1.8 around £50 per panel, they do last very well even if slightly neglected like ours.
Mark
Mark
bxzx16v
- x 34
Re: 406 V6 Coupe
I'm on afternoons at work this next week so I'll be using the 406 and leaving the blingo at home, looks like the scenic route to work for me then. I really must find some time to have a good poke around as due to work commitments etc I've not really done much or really used it as much as I should, any way it's out of the garage for the week while I fit some new exterior doors/frames to the house and the old doors are in the garage until I can get them to the tip.
Mark
Mark
bxzx16v
- x 34
Re: 406 V6 Coupe
I gave the 406 a run this morning before I went to work and had a sandwich and a bun while out. Took a couple of pics too.
Mark
Mark
daviemck2006
- x 496
Re: 406 V6 Coupe
That is a bonny looking motor Mark. I was going to do for one but I would have the same problem that made me sell the c4 VTS.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8159
- x 5606
Re: 406 V6 Coupe
One of the best designed cars ever and certainly best in it's class.
