HI
Does anyone know where I can get hold of the set of Xantia hydraulic hose return pipes part 5270N5? It costs almost 200€ from Citroen here! This seems absurd for a few bits of rubber pipe....
Any suggestions most welcome
Larry
Xantia return pipes- Part 5270N5
lazza
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
- x 8437
Re: Xantia return pipes- Part 5270N5
Which returns are those Larry?
lazza
err- have to take a picture i think. Hard to explain. It comes out of the hydraulic reservoir then there is a kind of 3 or 4 way connector of which several tubes leave, one of which goes to the return on the pinion valve.. if i get the chance tomorrow i'll send you a pic
lazza
think this is it:
or part nº 2 in this diagram:
- x 8437
I know the one Larry, it's informally known as the octopus...
That one is going to be expensive whichever way you look at it and a complete ***** to swap too...
Depending on where it's gone you may be able to effect a repair by replacing the bad bit with a metal tube.
Where has it failed and how?
Edit: Your picure is the one.. See why it's called an octopus now can't you!
citroenxm
- Fallen Hero
- x 70
They will be NFP in the UK no doubt now... though, I should have one, or two, with every front subframe or Xantia I stripped down.
Are you wanting new or a good used one??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
still showing as available from citroen UK Paul
00005270N5 OIL BACK HARNES 154.34 GBP 185.21 GBP 185.21 GBP
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Ok, well mine are 85 quid each then..............
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lazza
HI, in reply to Jim: The octupus failed at the pinion valve. I cut off the end with the split part and squezzed the tube back on- it's just long enough. However on examining it, most of the tube is cracked and probably only a matter of time until it fails again. I havent looked at the rest of it.
Not very encouraged that it may be so difficult to change though- i'll try to inspect it all when i get the chance and see if I could maybe do some kind of patching.
Otherwise, i'll buy one of those from citroenxm and wrestle with the octopus!
Cheers
Larry
Cheers
Larry
citroenxm
- Fallen Hero
- x 70
And NO mine wont be 85 quid!!
Let me know and Ill sort it out!
Interestingly, I had this wrestle recently with a S1, I had to remove cut and refit three times! I ended up bending the return pipe slightly to reach, but the pipe kept splitting. I did a temperay fix for the owner as he intends to get rid next month...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
citroenxm
- Fallen Hero
- x 70
Thats a point Addo, Lazza, is yours a UK car living over there with you, or a LHD Spanish car??
Dont think it matters, I think it will just mean you will have more return pipe to play with from the Rack Return..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lazza
Mines a LHD spanish car... maybe that complicates things?
addo
- x 95
