I've looked in the testers manual , and I'm still trying to work out if it's a failure if a rear door won't open from the inside?
Berlingo rear passenger door doesn't. Doesn't bother me, as I have the child lock on anyway, but the internal link in the door is broken.
Opens fine from the outside. I don't want to go and spend £70+paint+vat for a new handle assembly and pay someone to fit it *before* the MOT if it's not a fail. I want to know what else it's going to fail on first, ISYWIM..
Cheers
mike
MOT Query
- x 3298
Re: MOT Query
Tricky one. I would think that a door has to be capable of being opened from both sides under normal circumstances, but the child lock does 'override' this. If I had known earlier I could have asked when Gracie was having her partial MoT (and she has passed, so she has another year on the road!).
Northern_Mike
Re: MOT Query
If You See What I Mean...superloopy wrote:ISYWIM?
i.e. I don't want to go and spend a fortune on a new door handle and assembly only to have it expensively fail on other stuff, which it might well do..
Northern_Mike
Re: MOT Query
Found it :Hell Razor5543 wrote:Tricky one. I would think that a door has to be capable of being opened from both sides under normal circumstances, but the child lock does 'override' this. If I had known earlier I could have asked when Gracie was having her partial MoT (and she has passed, so she has another year on the road!).
6.2 Seats and Doors
Section B, note b: Drivers and front passenger door must be able to open from inside and outside the vehicle.
Note C: Any other passenger door must be able to open from outside the vehicle.
- x 3298
Re: MOT Query
That's that covered then. Still, it probably would be nice to get that sorted out for the future (in case of MoT changes, or when you have passengers on that side).
Northern_Mike
Re: MOT Query
I probably will at some point, but with those rear doors, I always end up opening them from the outside for passengers, as most of them appear quite hard of thinking when it comes to opening a different sort of door (push button at forehead level, pull door back).Hell Razor5543 wrote:That's that covered then. Still, it probably would be nice to get that sorted out for the future (in case of MoT changes, or when you have passengers on that side).
I believe a new door lock assembly is about £80, but it comes unpainted. Some chap in Poland sells the pin that's broken separately for about a tenner, but my success with door internals is very limited indeed, and I would end up making it far worse than it already is.
- x 94
Re: MOT Query
all passenger doors must be able to open fron in and outside for a UK MOT Mike
you only had to ask
EDITED
after re/reading your findings Mike
i thought!!!
you only had to ask
EDITED
i thought!!!
Regards, malcolm.
- x 94
Re:
superloopy wrote:Dont know which Mike you're replying to Malc but if it's me then we've never had a problem.
reminds me of Robert calling down the car production line, "Robert have you got my torque wrench"
this continued all the way down the line
no Mike it were Mike i were replying to
Regards, malcolm.
waynedance
- x 8
Work at mot station and as far as I know only front doors must open from inside. Cars may have child locks switched on and tester not allowed to mess with.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
- x 94
Re:
when you put it that way Wayne its obvious initwaynedance wrote: Cars may have child locks switched on and tester not allowed to mess with.
clear as mud
Regards, malcolm.
