is lpg any good
jacksun1987
is lpg any good
Unread post by jacksun1987 »
Bloke at work said he saw a xantia for sale 1.8 lpg x reg just wondering how much get per gallon are they good just general stuff
x 3281
Re: is lpg any good
Not sure about the mileage (I haven't ever had an LPG vehicle), but have you seen the cost? It is about half the cost of petrol.
Northern_Mike
They get a little less mpg. I used to get about 15% less mpg on LPG in my Jeep Cherokee than I did on petrol. Still well worth it though. It was cheaper to run than, in a weird coindicndence with the OP, our petrol 1.8 Xantia we had at the same time.
I'm just a grumpy Northern git.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Go well with turbos.
jacksun1987
Re: is lpg any good
I do 40 Miles a day but I have a 110 hdi I out in 50 pounds a week but each time I put that in its slowly topping it up if you know what I mean basically I'm bit breaking even but slowly gaining bit more fuel each time I top up
Northern_Mike
Re:
addo wrote:Go well with turbos.
Hell yes, my mate had an Impreza running on LPG. It ran massive boost and was running around 390bhp.
steelcityuk
Re: is lpg any good
Unread post by steelcityuk »
My XM 2.0 TCT went as low as 15 mpg on LPG. I sold it and bought my 2.1 SED XM. Runs on veg/bio mix. New veg oil is currently under £14 for 20 ltrs at the wholesalers. It's not as fast but I don't have to keep the spare wheel in the boot - the tank was under slung. I would rather like a 3.0 XM with LPG tho.
Steve.
not applicable
jacksun1987
Re: is lpg any good
Is the car I'm on about could be this http://www.carenthusiast.com/news1809/citroen1.htm" onclick="window.open(this.href);return false;
jacksun1987
Re: is lpg any good
Its not that one its a 1.8 forte conversion I cant insure ut becase it s lpg conversion
Northern_Mike
Find a better insurer. Most of them don't care as long as you've got the installation certificate.
Trainman
(Donor 2018)
x 43
Re: is lpg any good
Unread post by Trainman »
I run a Xantia 3.0 V6 auto on LPG, the car runs exceptionally well, I am currently in the process of having a Peugeot 407 converted, the Xantia on petrol gives me a return of about 25 mpg, here as the gas equates to 47.8 mpg if you equate pound for pound.
I have a 90 litre tank in the boot, and you have to allow a percentage of space for gas expansion, I can get about 75 litres in mine. I allow the car to do about 300 miles between top ups, but I have had upwards of 350 miles out of a tank.
Insurance wise, I have no problem with insurance, I use a company called Chris Knott and they have been fine.
Steve
http://c6owners.org/index.php
jacksun1987
Re: is lpg any good
I've got this rubbish eco co-op one was with co-op before then kwik fit wish I stayed with kwik fit I think the eco coop one has nothing to-do with co-op
jacksun1987
Re: is lpg any good
I phoned back the insurance. It wasnt one there computer. I didnt say anything this time. About it being lpg. So i can insure the car. If its all one the v5. Would the car be classed as standard. So that if i did make a clam. I would still be covered. Last time i told them it was lpg they said no. This time i didnt and i could go with it.
Northern_Mike
No.
Sent from my SM-N9005 using Tapatalk
jacksun1987
Re: is lpg any good
by the time runs out it will be good does anyne on here want to buy her seems sso good 1 owner from new full service history
