My LHM is ORANGE o_O
- x 694
Re: My LHM is ORANGE o_O
Are you sure its not mustard ?
skog77
It's weird. Spread thin it has that greenish LHM tint. Bit thicker and its mustard. Bit thicker than that, and it's red-ish Coca Cola.Mandrake wrote:Are you sure its not mustard ?
I'm not going to drink it though.
xantos
- x 10
I got that information from a Citroen specialist... Well you learn something everyday!Mandrake wrote:Where do you both get that idea from ?skog77 wrote:ATF does that too. (-expletive removed-), i'll change it as fast as i can.xantos wrote:If it is LDS change it quckly! It eats o-rings in LHM sytem! If not change it anyway...
Why do people do this stuff
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
- x 1480
You can tell if it's LHM - it has a very distinct smell.
LHM in mine was nearly that colour, not having been changed for well over 100k miles - I sort of never got around to it.....
LHM and LHS are essentially compatible from a seal point of view - the C5 front strut return hoses are the same part number as used as far back as the BX
- x 694
Fixed that for you Richard, so as not to further the confusion in this thread.RichardW wrote: LHM and LDS are essentially compatible from a seal point of view
Nice find - which confirms what we thought. They're no more different really than going from semi-synth to fully-synth motor oil...RichardW wrote:the C5 front strut return hoses are the same part number as used as far back as the BX
I wonder if LDS could be used in an LHM car like a Xantia with any improvement in fluid longevity ? Not that I'd want to chance it (long term) when it's more expensive, at least not until LHM becomes unobtainable, then we may have no choice...
Old-Guy
- x 24
Make your 'new' Xantia even happier and clean the two filters in the LHM reservoir head - be very gentle with the nylon gauze, it is likely to be brittle with age. Brush gently with a little clean petrol (will evaporate and not contaminate the LHM) using an old SOFT toothbrush. DO NOT use a compressed air line!
Make sure that the largest pipe (the uptake to the hydraulic pump) makes a good seal on the stub of the reservoir head. This stub is only plastic and the 'rubber' hose gets hard with age, so it's better to push the hose over the bulge to where it was then pull back slightly before putting on the clip.
Northern_Mike
Here's some old LHM I took out of my Activa, complete with bits (!)
I'd not worry too much about yours to be honest.
qprdude
- x 14
Looks more like an old nappy!
Rick.
2013 Citroen DS 5 D/Sport
Northern_Mike
It actually had a consistency of a bad pint of bitter when it came out! I guess then the car was 12 years old and had 95k on the clock and it had never been changed.
