Hi
I have a 2004 Citroen C5 VTR. It runs perfectly well apart from the last two days or so. When I am driving it for around half an hour, the rear suspension seems to jump up without warning. It then goes to back to normal then after ten minutes or so jumps up again. I have never experienced this before. I am taking it to a garage on Monday but wondered if this is something that is a common problem
Thanks,
Craig
Citron C5 Suspension Issue
- x 1240
Re: Citroën C5 Suspension Issue
On the XMs and Xantia's it was usually due to the height corrector sticking but have not experienced any problems with mine yet so don't really know.
- x 5672
My best guess based on similar but not the same problems would be the rear height sensor.
- x 3296
I knew I had read about this somewhere! The pictures have been lost, but it would appear the problem is the solder joins;
http://www.frenchcarforum.co.uk/forum/v ... 56736&hili" onclick="window.open(this.href);return false;
