Xantia aircon
- x 3296
Re: Xantia aircon
Mattel, if you are outside of the North American continent, and Hasbro if you are inside said continent!
Xantia97
Re: Xantia aircon
Thank you for clearing that up, I thought I was right using 'dryer', for once the French is more obvious 'bouteille deshydratante'
don't get to say that very often about the French language
1997 Xantia 1.9TD LX (owned for 14 years) - Snoopy
Gone but always remembered
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
Xantia97
Re: Xantia aircon
If Northern_Mike and Citroenxm are trying to contact me by PM I haven't received anything - have sent both of them a PM regarding the spoiler but have had no response although both messages have been read apparently. Just don't want them to think I am ignoring them
I know this is off topic but both posted on this thread last night.
Juliet
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
addo
- Sara Watson's Stalker
- x 95
Xantia97
Re: Xantia aircon
Good idea about the TX valve, just have to find where it is and judge whether we are capable /have the facilities to change it.
Thanks,
Juliet
Thanks,
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
citroenxm
- Fallen Hero
- x 70
Re: Xantia aircon
The TX valve was discussed on another thread, I learnt it is RIGHT UNDER the LHM tank, where the Air Con pipes enter into the evaporator in the car! So its a bit of a strip down.
Ive never needed to remove or replace a TX valve from open systems and have them working perfectly. The key is a GOOD LONG Vac down, and a slow recharge and ensure the correct amount of gas an system oil is in there.
The key is the Vac down and ensure it holds a vaccuum.. Basically the same as gassing up with an Ozone friendly gas with a Dye in it to look for leaks.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xantia97
Re: Xantia aircon
I guessed the TX valve might be beyond our capabilities. Think we will go ahead without changing it and hope for the best, now I need to find an aircon specialist who will do a good job of the Vac down - easier said than done here!
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
citroenxm
- Fallen Hero
- x 70
Re: Xantia aircon
What a shame your so far away. So far what Ive read I could have done all for you so far!!
Ive got a Vac Pump, and Vac Guages, but just run out of R134a gas... Need to get some more in..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xantia97
Re: Xantia aircon
We should have stayed in Wales (actually Forest of Dean but spitting distance to the border, I'm Welsh by birth), would have been much better for the cars all round
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
- x 3296
Re: Xantia aircon
Well, after northern_mike has met up with you during his French holiday you could always go for a holiday in Wales!
Xantia97
Re: Xantia aircon
I wish! We can't leave France at the moment due to one of the cats being on long-term treatment from the vet, it takes two to get the tablets down his throat! We can't even find a good pet-sitter to give us a break
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
- x 3296
Re: Xantia aircon
You might want to try this trick. Crush the tablets to a powder, and then mix the powder into some Primula cheese (you know, the stuff that comes in tubes!). Then offer that to the cat.
It helps if you get a cheese the cats like (such as prawn flavoured), and then give them a small amount daily as a treat.
Xantia97
Re: Xantia aircon
Been there, done that, got the tee-shirt
He can smell the tablets!
This is the larger Maine Coon at 10kg so his dosage is the amount for a small dog and he is the fussiest cat in creation, it is easier to put the tablet straight down his throat, if he's just woken up it's easy, but otherwise out come the claws and teeth
He's a lovely cat, a big gentle giant except for pills and grooming
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
- x 3296
Re: Xantia aircon
My mums' cat Waah-Li didn't like Primula cheese, but she definitely had a thing for clotted cream, so she used that instead. Mind you, Waah-li wasn't that fussy when it came to taking pills.
Whenever we had something for pudding that used clotted cream Waah-li would get a finger dab of cream, and she would enjoy it and then sit off to one side with an expression of "If there is any more going I wouldn't say no". However, if she didn't get her treat she would sit off to one side muttering loudly about how hard done by she was! (and you know how loudly cats can mutter!).
