x 1484
Re: Simon's new Xantia V6 blog
Mandrake wrote:so I'll have to find someone willing to weld it instead of just an exhaust parts swapper. :roll:
You take it off, and I'll weld it :)
x 694
Unread post by Mandrake »
You're a glutton for punishment Mr W :lol:
From what I can see if the back of the car was up on ramps we could remove the rear rubber bushes and drop the entire exhaust down at an angle without disturbing any joints and do it in place. I think its only rusty on the bottom side where condensation has pooled anyway, so a 180 degree lap welded patch is probably all it needs...
Northern_Mike
Mandrake wrote:Yes, it flew through! :-D
Great news Simon, well deserved after all your hassles with the old one. I hope this car serves you well and you get the enjoyment you wanted out the last one, but didn't really get. :lol:
KP
x 27
Unread post by KP »
Mandrake wrote:And Will (KP) picked up the old Xantia about an hour ago, so its a bit of a bittersweet day...
And it's been at it's new home for about 15mins now :)
Not a blip or burp all the way other than a coolant temp drop issue that worries me the first time but she reaches the many leptoons quite quickly so that soon got reigned in and the cruise is different from my 2.5xm as it seems to adjust in 1mph increments instead of 2-3 :) anyway all good and another spin tomorrow!
x 8325
Excellent :-D I was sure it would... My pre-MOT is a very tough one.
Trainman wrote:AH........ and relax..........
Yes, absolutely :-D
KP wrote: the cruise is different from my 2.5xm as it seems to adjust in 1mph increments instead of 2-3 :)
Yes, it's a proper vacuum one rather than the 2.5's digital fly by wire...
x 694
Although I'm sure its technically digital, the cruise adjusts in an analogue fashion - hold up or down and it slowly increases or decreases the speed, and then locks at whatever the current speed is at the moment you release the stalk.
I'm pretty sure you can make adjustments smaller than 1 mph, as you can easily match the precise speed of the car in front of you.
By the way when you re-engage cruise after using the brakes, flicking it quickly up resumes the previously memorised speed while flicking it quickly down resumes cruise at the current speed.
I'm not sure whether the S1 cruise has quite the same behaviour - I haven't thoroughly tested it yet.
KP
x 27
Unread post by KP »
It feels odd to be honest and a little slow but has the true retro-ness of the accelerator moving under your foot when it changes! I haven't driven a car in a while that has done that as I never got a chance to really test the cruise on the last one. Should be the same across the board, it's how the xm works Simon jut with bigger incremts :)
x 694
Yeah it is a bit slow to make a big adjustment to the speed - I normally use the brake or accelerator to quickly get to the desired speed then flick the stalk down to memorise that speed and activate. I only use the the stalk for fine speed adjustments and to engage/disengage.
x 8325
KP wrote:It feels odd to be honest and a little slow but has the true retro-ness of the accelerator moving under your foot when it changes!
It's great isn't it. Like a ghostly foot on the throttle... I love it.
Yes, all vacuum systems are slower simply because they have to generate the vacuum to operate the bellows... I never find it a problem.
And yes, the stalk behaviour you experience is a bout right Will...
Never forget inside the ECU is a Z80-based 8 bit microprocessor. It's not short of a bit of wit :-D
KP
x 27
Unread post by KP »
Spectrum power!! Well it holds speed and that's what matters really :)
x 8325
KP wrote:Spectrum power!!
Indeed :lol: And ZX81 :wink:
Good job you don't have to programme the cruise control every day from a cassette tape!
KP
x 27
Unread post by KP »
Well it does have a cassette player lol
x 8325
KP wrote:Well it does have a cassette player lol
maybe that's what it's for :wink: :lol:
x 694
Quick question for the experts - how do I re-program the immobiliser code ? The owners manual is missing in this car (something I also want to rectify at some point) and I didn't have an immobiliser or alarm on my other S1.
I ask more so that I know how to avoid accidentally changing the code through fiddling than some burning need to change the code right now :lol:
Also if I disconnect the immobiliser will it remember its code if I ever reconnect it ? Is the code stored in the immobiliser unit, the engine ECU, or both ?
One more question while I'm at it - where is the keyhole that enables the siren ? I noticed when I set the alarm off from disconnecting the battery the headlights flashed on reconnection but there was no siren...
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
I will scan the relevant pages in the morning for you........ there's about 8 of them
Steve
http://c6owners.org/index.php
