Hello all after fitting a new rear ride height sensor the back is to high, i realise that i should be using Lexia to sort it out but dont have one, im sure i read some were you can do this manually?
Thnks
Andy
c5 2.2hdi ride height
Monkeyfeet
Re: c5 2.2hdi ride height
Until some one more knowledgeable comes along:
If you can do it on a Lexia, usual thing is to post where you are, a lot of FCF members have Lexias and are willing to lend their services.
On Xantias you could move the fitting clamp round on the roll bar. Car could drop like a stone for a small adjustment so you can't go underneath without axle stands etc.
Personally I think you're right re the Lexia though.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
morto
thanks mate ive jacked the rear wheels off the ground and put a third jack on the towbar so not to get killed,, ive found the clamp and the bolt but looks well rusty i recon i wud end up snapping the bolt...
2002 2.2hdi C5
- x 5673
morto
Thanks mate ive used WD-40 and left it a hour or so and it looks like its moving.. anyone know whitch way to go with the u clamp to lower the suspension i understand you only need to move it a tad.. and also someone said becrefull as the ecu always tells the pump to lower the suspension at 70mph so not to go to low
thanks
Andy
thanks
Andy
2002 2.2hdi C5
- x 3296
Plus Gas makes WD40 look a wimp. WD40 was never designed as a freeing agent, it is a water dispersant (hence WD).
Northern_Mike
- x 5673
There is now a WD release oil.
I know because I have some.
Sent my son to buy Plus Gas this afternoon and he came back with the WD, said they (Halfords) didn't have it.
I suspect I have the dreaded trailing arm bearing sickness and the car is going for MOT and fixitation on Monday so have started dousing the R-clips with it.
Too early to say if it is any good.
Ed: Beaten to it by Mike (as usual).
- x 3296
Ah, that I didn't know. Oh well, you live and learn.
morto
ok rotate u clamp countercolckwise to lower suspension on the rear but not to much .. i use jacks and take battery lead off.... not to get killed
2002 2.2hdi C5
