CV boot fitting
KP
x 27
Re: CV boot fitting
Unread post by KP »
It's all a bit double Dutch to me but I'm sure when i come to taking it apart it will make much more sense :)
Thanks guys :)
x 94
Re: CV boot fitting
Unread post by citronut »
ps.
Will
if you send me the last 8 of your chassis/VIN No. i will get you the OE price and part No. for the snap ring
Regards, malcolm.
x 8213
Re: CV boot fitting
citronut wrote:actually the inner triax comes apart far easier than the outer as the trax is held on to the shaft with a normal circlip,
remove this then just tap the splined shaft end through and out of the spider,
That makes it a lot easier Malcolm but I could have sworn My Activa shaft spider did not have a circlip. Maybe it's just that one is a bit different to the rest. Hope so!
x 94
Re: CV boot fitting
well i have not taken a shaft apart from an Activa, but all the PSA shafts i have had apart have had a circlip holding the triax on
Regards, malcolm.
x 94
Re: CV boot fitting
here is the snap ring for a BE3 AND WITH ACTIVE ANTI-ROLL
this might not be as on your car Will,
DRIVE-SHAFT SNAP-RING
24,36 X 27,36 - 1,5
price and part No.
0000329406 DR SHF SNAP-RG 0.19 GBP 0.23 GBP 0.23 GBP
Regards, malcolm.
