V6 Xantia......... the beginning of another adventure
Trainman
(Donor 2018)
x 43
Re: V6 Xantia......... the beginning of another adventure
Unread post by Trainman »
Excellent, gives me an idea where to look now.
Steve
http://c6owners.org/index.php
x 6776
Gosh Steve :shock: My first thought on seeing that picture was "You've been busy today" :lol:
Trainman
(Donor 2018)
x 43
Nope not touched it at all, left it alone all day, I just thought that seeing as David's box was similar it was good to ask the question....
Steve
DHallworth
Donor 2023
x 137
Unread post by DHallworth »
If you look at the state of the workshop floor around it you can see why I am getting rid of stuff I don't need!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 6776
What's that sticking out of the side of the gearbox David? Looks almost like a driveshaft?
Chris570
x 29
Unread post by Chris570 »
CitroJim wrote:What's that sticking out of the side of the gearbox David? Looks almost like a driveshaft?
He's just pleased to see you.
or it's a shaft as mentioned in the ad ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'
DHallworth
Donor 2023
x 137
It is a stuck shaft Jim. I welded a piece of pipe to it to see if it could be budged but ran out of time and haven't tried again since!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
daviemck2006
x 492
Unread post by daviemck2006 »
Carriage fees will be significantly more expensive with a drive shaft attached. Jim may need two flasks! :mrgreen: :lol:
Skoda Karoq 1.6tdi 2018
Citroen dispatch 2014
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
x 6776
What brand of flasks Davie?
That'll be a fun task, extracting that shaft David. Heard of them getting stuck before...
Trainman
(Donor 2018)
x 43
First and foremost a HUGE thanks again to Jim for posting me the switch...
Guys you were right, it wasn't to bad to do.
Bog standard start, air filter and battery off so I could see the little devil in situ
next trace the cable back to the joint, located under a pile of other stuff, you need a lat blade screwdriver to just lift the brown connector lock, before it will come apart, oh and the wire comes out from the top of the plug, because the plug itself has a plastic push clip holding it to a bracket.
There's 2 x 10mm bolts, one at the top and one at the bottom, which you (surprisingly :roll: ) can't see, the only way to get at the bottom one was a small socket, I tried everything else including a swivel ring key, There's also a 13mm Nylon tight nut which holds the cable to the switch, so I started with the top 10mm, then 13mm and finally bottom 10mm. There are also a couple of small LHM return pipes that I kept pulling off so beware of those, they just push back on. TIP When you have the air filter off, put something over the air intake pipe, I dropped a socket down there, which took me 10 mins of cursing and fiddling with a magnet before I got it out.. :twisted: :twisted:
This one shows the spindle the switch sit's on, after the old one was removed, this is the old switch
and the new one supplied by the "Oracle" AKA Sir Jim
I took her out for a quick spin after finishing and all appears good, the real test will be tomorrow as I take her over to Runcorn in the morning.
Steve
Trainman
(Donor 2018)
x 43
Mike, if you driven 've off after starting the car, it wouldn't change out of first gear, however, if you stopped, put the car into reverse, I here was a double thump from the gearbox, if you then when back to 'drive' the would only pull away in top gear, and it didn't matter what gear you tried to selected it was either first or forth.
What confused me most, was if, after driving off in forth, you stopped the car and turned the engine off, when it was restarted it would be in first again, and again wouldn't change up gears, either automatically or manually..
Steve
x 6776
Steve, I'm absolutely delighted to hear the news 8-) :-D Well done sir =D> Completely overhauling the 'box is just a simple extra step for you now :wink:
Honestly, brilliant :-D
What's that splash of LHM in the last photo on the pressure regulator bracket? It's not the in the first photo :?
Trainman
(Donor 2018)
x 43
It's from where I pulled a return pipe off Jim, cleaned up before being put back together
Steve
x 6776
Trainman wrote:It's from where I pulled a return pipe off Jim, cleaned up before being put back together
Ahh, that's OK then :-D I know the one, on the Hydractive electrovalve. So easy to do...
bxzx16v
x 35
Unread post by bxzx16v »
Hope everything is ok now Steve, that V6 has been pushing you to the edge #-o.
Mark
