V6 Xantia......... the beginning of another adventure
KP
- x 27
Re: V6 Xantia......... the beginning of another adventure
Do you even have to go Steve if they could get it to the train station it could surely get upto you?
Trainman
- (Donor 2018)
- x 43
Will, different companies and the politics make it a headache, easier to go myself.
Steve
http://c6owners.org/index.php
KP
- x 27
Ahhh thought they stopped off at Milton Keynes
Nightmare indeed
post it tomorrow and should be with you Thursday, even get it delivered to me if you want and then pick it up on your way past
Nightmare indeed
Trainman
- (Donor 2018)
- x 43
Thanks Will, but getting it delivered to work is easy, it's what I do with fleabay, some of our trains do but they via Brim, so it's 3 hours each way.....
Steve
Trainman
- (Donor 2018)
- x 43
Just been playing about on fleabay and noticed a 4HP-20 gearbox for sale.out of a 2.2 C5 now that's got.me pondering, are these switches definitely unavailable from Citroën?
Steve
- x 8397
Steve,
PM me your address (or a suitable alternative address) and a switch will be in the post to you later this morning..
Has to be today as this is the only day I can get to a Post Office at a reasonable hour..
OK?
OK?
Trainman
- (Donor 2018)
- x 43
Jim, You're a star, PM to follow.................
Steve
Northern_Mike
Re: Re: V6 Xantia......... the beginning of another adventur
Go to http://www.parcelmonkey.com" onclick="window.open(this.href);return false;Trainman wrote:superloopy wrote:Must've been under the V6 'influence' at the time of reading eh ....Trainman wrote:
DEAR GOD......... I didn't spot thatenough said
I guess I'm just wary, getting to the motorway is fairly easy and shouldn't put to much strain on the car, my concerns are more around the Peterborough end and getting stuck in traffic, with the added weight of the trailer.
Great that's good, at least a bumpy like me can do it, so where to get one from, I happy to travel, to get one in person that way I know I have it, but I will settle for it being posted......
Create an account.
Ensure parcel is ready to go.
They'll pick it up and do next day for about a tenner.
I used them lots for sending bits around the country. It's actually cheap courier work done by City Link. Sent lots of laptops. never had an issue with them.
Enviado desde mi GT-I9505 usando Tapatalk
Northern_Mike
- x 8397
Steve, PM seen and is in progress
Mike, you're forgiven... You are in Bogota after all..
On the same subject, those ParcelMonkey things work well.
I see you can now deposit a UPS parcel with your local corner shop now. Join up, print off the labels and job's a good 'un...
Also, UPS parcels can be sent to your local corner shop for collection.
Used it. Works a treat.
- x 8397
Steve,
Switch is now in the hands of Postman Pat and his colleagues. It should be with you tomorrow..
A 13mm spanner, a screwdriver and a small 10mm socket is all you need to swap it. 30 minutes from start to end should see it done a treat
And that time includes a cup of tea half way through
KP
- x 27
If you get stuck Steve let me know and I'll lend a hand a hammer
Trainman
- (Donor 2018)
- x 43
Guys, thanks very much, i'll be in touch tomorrow afternoon when I get home from work
Steve
Trainman
- (Donor 2018)
- x 43
NO I haven't removed the gearbox before you ask or shout at me, this is a picture of the one destined for Jim, but it got me thinking....... Can somebody highlight the switch I'm changing to give an idea.
Steve
- x 1459
Do you see the cable with a connector clipped to the heat exchanger? The switch is on the other end of the cable.
