Battery relocation
KP
x 27
Battery relocation
Unread post by KP »
Has anyone got a guide or come across one for battery relocation to the boot of a Xantia?
Im sure its been done by someone but I cant recall who by....
Chris570
x 36
Re: Battery relocation
Unread post by Chris570 »
The principal is very simple, big thick earth cable into the boot crossmember (not a thin bit of metal). Then a sod off big cable for the positive feed onto the starter motor and then take feeds from that into the main fusebox.
Personally though, I wouldnt. It's a lot of hassle and although you're moving weight from the front to back you are then making the o/s a LOT heavier than the n/s
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
x 8362
Makes the Activa Accumulator more accessible though :wink:
Chris570
x 36
CitroJim wrote:Makes the Activa Accumulator more accessible though :wink:
but would make changing the rear bulbs harder
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8362
For every action there's a reaction :)
KP
x 27
Unread post by KP »
Maybe it doesn't have to be the boot then, maybe the rear divers rear footwell?
The problem that's the most annoying is the running of cable as the xantia was never designed for high rear electrical loads :(
x 8362
KP wrote: The problem that's the most annoying is the running of cable as the xantia was never designed for high rear electrical loads :(
You can possibly run it along the tray carrying all the hydraulic pipes to the rear Will..
KP
x 27
Unread post by KP »
Would that support big enough + cable though as it would need to be chunky to supply the starter as the easiest way i see is to earth the negative near the old tray and then somehow mate the old + lead onto a new one possibly with some kind of block like half a Anderson connector or such like allowing easy removal in the future if needed.
Other option is a smaller lighter AGM battery as there isnt a huge load on the battery once running so you just need enough to crank for a few seconds...
x 8362
KP wrote: you just need enough to crank for a few seconds...
True. The TCT is never a hard engine to start...
KP
x 27
Unread post by KP »
Wonder how small a battery could be gotten away with.... maybe 40ah...
Chris570
x 36
I'm still not convinced moving the battery is the answer as in the scheme of things the battery isnt that heavy. Now an LPG tank in the Boot......................
Also, don't try and reuse the original battery leads, you will regret it I promise ;)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
KP
x 27
Unread post by KP »
If I did it then it would be quick release clamps like i put on the TD before i sold it.
TBH i think the easier route is to get a lighter AGM battery. i wonder if there is anywhere that makes a plastic bonnet for the xantia at all as they weigh a fair chunk of meat as well....
