open curcuit parking sensor
boristhespie
x 4
Unread post by boristhespie »
Ok paeking sensors dont work. One was replaced according to dealer receipt that came with car. It also mentions open curcuit on left rear sensor. Can I just replaxe sensor or are we talking about an open wire somewhere/anywhere?
C'est pas possible!
Old-Guy
x 22
Re: open curcuit parking sensor
Unread post by Old-Guy »
I'd guess that you're in effect quoting the text associated with a fault code. It's anyone's guess as to where the fault lies, but if one sensor was replaced and the parking sensors aren't working at all, it probably isn't a simple replacement because you'd expect a mechanic with half a brain to have tried that when replacing the faulty sensor.
hamster99
Unread post by hamster99 »
If you know which sensor is showing as having the open circuit then first thing to check would be whether the connector plug on the back is loose or has come off.
You can get at the backs of all sensors without removing the bumpers.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
dnsey
x 19
Unread post by dnsey »
If the ECU has been read recently with a Lexia clone, chances are it's the firmware bug recently reported here, which can apparently be fixed with Peugeot Planet.
x 1044
Unread post by wheeler »
Most of the time I find the sensors fail due to water ingress, normally easily spotted by signs of corrosion on the connector & around the sensor pins.
