V6 Xantia......... the beginning of another adventure
KP
- x 27
Re: V6 Xantia......... the beginning of another adventure
Try lots of penetration fluid first and then heat Steve. Do you have an angle grinder incase it gets bad?!
Trainman
- (Donor 2018)
- x 43
I've tried the penetrating fluid and I don't have access to a blow torch, my old man's got an angle grinder so I will head over there next week and do it there, that way if I need anything, he can nip and get it for me.....
Steve
http://c6owners.org/index.php
KP
- x 27
Sounds like a good plan Steve
- x 8391
I like the idea of a Xantia trailer for yours Steve... Needs to be the same colour though... Perhaps use an estate back-end?
When is the National? I want to try to get to it and I hope I can.
Shall I bring the C1?
KP
- x 27
Towing dolly and you could bring two cars then Jim! If the towcar breaks down you can still continue and just send the failed car home on the flat bed
- x 8391
Hey!!! Good thinking WillKP wrote:Towing dolly and you could bring two cars then Jim! If the towcar breaks down you can still continue and just send the failed car home on the flat bed
Trainman
- (Donor 2018)
- x 43
Will you two pack it in, I can get in enough trouble without your help.... thank you very much.....
National is 18 - 20 July, oh and Jim I'm taking the Xantia if you can fetch that switch.
Steve
KP
- x 27
Hmmm. An estate with the front end subframe changed to a static dolly setup...
Suspension could remain unchanged then and stripped out and lined would prob be about 700kgs or less all in....
- x 8391
SorryTrainman wrote:Will you two pack it in, I can get in enough trouble without your help.... thank you very much.....
Excellent. I have checked with my social secretary and I'm good for that oneTrainman wrote:National is 18 - 20 July, oh and Jim I'm taking the Xantia if you can fetch that switch.
Remind me nearer the time. You know what I’m like
Trainman
- (Donor 2018)
- x 43
That almost sounds sincere......... but only almostCitroJim wrote:SorryTrainman wrote:Will you two pack it in, I can get in enough trouble without your help.... thank you very much.....![]()
Oh don't worry about that, I won't forget.......CitroJim wrote:Excellent. I have checked with my social secretary and I'm good for that oneTrainman wrote:National is 18 - 20 July, oh and Jim I'm taking the Xantia if you can fetch that switch.Steve, I left the switch with Paul thinking he'd see you first but no worries, I have another one...
Steve
Trainman
- (Donor 2018)
- x 43
I've spoken with Paul tonight who has confirmed that the S1 and S2 tow bar are the same fitting, and the that yours truly (dozy sod that I am) was looking at the wrong set of holes....
and there m'lud, the case for the prosecution rests
There for I've taken the bar off sale and now require the use of and angle grinder (that's hat dads are for
) once all the old bolts and excess rust has been removed I plan fitting it ready for the national.
Steve
- x 8391
Excellent
So when are you going to start work on the Xantia trailer then Steve?
< runs and hides>
Love your new Avatar
< runs and hides>
Trainman
- (Donor 2018)
- x 43
It's especially for people who keep suggesting more work for me instead of less.........CitroJim wrote:
Steve
- x 8391
Yes but think of the benefits of a nice trailer Steve. They are boundless...Trainman wrote:It's especially for people who keep suggesting more work for me instead of less.........CitroJim wrote:
Trainman
- (Donor 2018)
- x 43
Plans are afoot......... for fitting the towbar on Tuesday, I went and picked the ramps up from my dad's yesterday. So hopefully everybody thing goes well.
I also got an issue with a sticky rear height corrector, which if I'm feeling brave enough I will have a look at and there's air in the system somewhere, it's a bit bouncy at the moment, and when I put her in low, she goes down nice and gently and then drops all of a sudden at the front, so system will get bled whilst I have the ramps so I can get under the front, because there's sod all room to get your hand in otherwise.
I also noticed there's a slight knock from the exhaust, which I think is rattling on the heat shield, so another thing to have a look at, and yes I'm doing t outside, so it should start raining Monday.
Steve
