Are these the same? Was told that they will need replacing soon.
508752 and 9807130080
Are both parts related to the rear suspension? What part is the gaiter?
Part numbers
osx
- x 15
Part numbers
C5 X7 Exclusive 2.0 HDi Auto
- x 94
Re: Part numbers
9807130080
C5 (X7)
C6
DT20C TURBO DIESEL
UNTIL RPO 10618
DT17TED4 TURBO DIESEL SINCE RPO 10619
DIESEL TURBO DW12BTED4 FAP
INJECTION ES9A SINCE RPO 10619
the only diference i can see on service citroen between the two part No.'s is the "UNTIL RPO 10618" line
C5 (X7)
C6
DT20C TURBO DIESEL
UNTIL RPO 10618
Regards, malcolm.
osx
- x 15
Re: Part numbers
Thanks. Having a closer look and it's not very clear. They want 2 x 508752 for the rear suspension and 1 x 9807130080 for the front suspension. From a quick look I was under the impression that both parts were for the rear suspension.
- x 3522
Re: Part numbers
508752 is a front left drop link (Citroen refer to it as a bar link), 508753 would be a right hand one. These drop links go regularly - surprised they're not listed as a service item
9807130080 is a rear drop link - these are not handed so I'd guess it's 2x 9807130080 and 1x 508752 they'll be recommending.
- x 94
Re: Part numbers
sorry i missed the important bit of front and rear
bobins is correct,
FRONTS
X 1 5087 52
ANTI-ROLL BAR LINK
LEFT = N/S
X 1 5087 53
RIGHT = O/S
REARS
X 2 5178 52 this is the old No. for this drop link
RP 98 071 300 80 and this is the new No. for the same
ANTI-ROLL BAR LINK
bobins is correct,
FRONTS
X 1 5087 52
ANTI-ROLL BAR LINK
LEFT = N/S
X 1 5087 53
RIGHT = O/S
REARS
ANTI-ROLL BAR LINK
Regards, malcolm.
osx
- x 15
Re: Part numbers
Thanks guys. Ordered both front and rear as I would rather replace all of them in one go. If it is a quick job I might do it myself but wouldn't mind paying £40-50 labour if it is a messy job
- x 3522
Re: Part numbers
It's a fairly straightforward job to do the fronts - I've done it myself on mine. Apart from the usual array of sockets, spanners, jacks, axle stands, tea, plasters, you'll also need a 5mm Allen key and a T40 Torx bit for the front links - preferably both bits that can be mounted in a ratchet driver..... at least that's what the genuine Citroen drop links use ! The T40 is for holding the long upper part of the drop link steady, and the 5mm allen is for the lower one. When fitting the new links, the nuts should be tightened to: upper one 205Nm and the lower one to 55Nm. It can be a bit of a fiddle to drive out the long portion of the upper part of the link from the suspension, so twisting the rod with the T40 bit and/or a suitable drift and careful use of percussive maintenance may be needed
As for doing up the rears, - 40Nm for top and bottom nuts.
cheers,
Robin
cheers,
Robin
osx
- x 15
Re: Part numbers
Received the following part for the rearcitronut wrote: FRONTS ANTI-ROLL BAR LINK
X 1 5087 52 LEFT = N/S
X 1 5087 53 RIGHT = O/S
REARS
ANTI-ROLL BAR LINK
517846 instead of 517852. Are these compatible (look the same) or should I return them?
- x 94
Re: Part numbers
517846 does not come up on service citroen,
Regards, malcolm.
- x 3522
Re: Part numbers
517846 is, I think, just a Peugeot part number for the same link rod. 517846 and 517852 certainly seem to be listed in various places as interchangeable.
osx
- x 15
Re: Part numbers
That is probably right.
- x 94
Re: Part numbers
bobins wrote
"517846 is, I think, just a Peugeot part number for the same link rod"
NOP
i just ran it by pug service box that alo does not recognize it
but the 517852 shows
11 document(s) found for 508
24 document(s) found for 407
NOP
Regards, malcolm.
osx
- x 15
Re: Part numbers
They are listed as interchangeable at Eurocarparts and other sites when checked with registration
