Pauls HDI Xantia Exclusive.
KP
x 27
Re: Pauls HDI Xantia Exclusive. Yeesssssssssssss!!!!!!!!!!
Unread post by KP »
I was meaning I've towed with a c5 hdi90 and towed with the rangie and a 2.1td xantia so know what it's like having and not having the grunt :) can't wait to get the rangie sorted as it's a proper towing machine :D
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ahh, 2.1 TD Xantia does NOT delivery its power/torque the same as a HDi 110..
Taffy, Service interval on the HDi 8v is 12,500 with semi synthetic.. doesn't hurt these what so ever!
A very sad...
1994 XM 2.1 d auto
x 1493
Brilliant Paul!! Odd that the reg from an apparently good pump appeared to give the same symptoms as your previous one. Perhaps the previous owner never gave it any beans... Anyway, top job!
citroenxm
Fallen Hero
x 70
MOST Thanks to you Richrd and your valuable information and tips, and help!!
A very sad...
1994 XM 2.1 d auto
Eddie Nuff
New User
x 32
Unread post by Eddie Nuff »
I change the oil in my HDi every 6 months, regardless of mileage covered. Doesn't use a drop in between.
About bloody time you found out what was wrong . . . beginning to think you'd lost the plot out there on your own, by yourself, out in the wilderness. :lol: :mrgreen:
citroenxm
Fallen Hero
x 70
I think I already have Neil, Took TOOOO long to sort!
However, just goes to show, there can be MORE then one at a time faulty!
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
279k this week end.. going better then ever!
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
You need to put your full update on here including the fix Paul :)
You've know beaten the highest mileage I've had in a hdi engine now!
x 8422
Game on for 300K then Paul :)
citroenxm
Fallen Hero
x 70
I have done the Full Fix on her on previous pages, it was the fuel regulator on the end of the pump...
Simple As!
Yea, not sure Ill get there Still Jim, heater matrix IS showing early signs of leakage, with a slight curry smell and windows steaming up rather then demisting..
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Have you bought some forte stop leak and bought yourself sometime as that may help get here there? And for you a heatermatrix job isnt a biggy is it now ;)
citroenxm
Fallen Hero
x 70
NOPE!
I religiously DO NOT beleve in adding ANY sort of stop leak what so ever to any cooling system! if its stopping a leak, what else is it blocking up!
A very sad...
1994 XM 2.1 d auto
x 3296
There is one thing. IIRC Valeo require you to use Forte stop leak when fitting one of their heater matrixes for their warranty to be valid. I have got this from somebody else posting it up on the forum.
citroenxm
Fallen Hero
x 70
Why on earth would you put in a stop leak after fitting a new part! I NEVER have on ALL the Matrix's Ive done!
A very sad...
1994 XM 2.1 d auto
x 3296
I don't know, Paul, as I have yet to have the pleasure of doing one. All I can say it that several posts indicate Valeo insist on Forte Stop Leak as part of the installation process for their warranty to be valid;
http://www.frenchcarforum.co.uk/forum/v ... ix#p371593" onclick="window.open(this.href);return false;
I found 25 posts under a search for 'Valeo Forte Matrix'.
EDIT; Maybe it is like putting Fernox into a new central heating system to prevent any lime scale from forming and causing future problems?
