Pauls HDI Xantia Exclusive.
KP
- x 27
Re: Pauls HDI Xantia Exclusive. Yeesssssssssssss!!!!!!!!!!
I was meaning I've towed with a c5 hdi90 and towed with the rangie and a 2.1td xantia so know what it's like having and not having the grunt
can't wait to get the rangie sorted as it's a proper towing machine
citroenxm
- Fallen Hero
- x 70
Ahh, 2.1 TD Xantia does NOT delivery its power/torque the same as a HDi 110..
Taffy, Service interval on the HDi 8v is 12,500 with semi synthetic.. doesn't hurt these what so ever!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1496
Brilliant Paul!! Odd that the reg from an apparently good pump appeared to give the same symptoms as your previous one. Perhaps the previous owner never gave it any beans... Anyway, top job!
citroenxm
- Fallen Hero
- x 70
MOST Thanks to you Richrd and your valuable information and tips, and help!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Eddie Nuff
- New User
- x 32
citroenxm
- Fallen Hero
- x 70
I think I already have Neil, Took TOOOO long to sort!
However, just goes to show, there can be MORE then one at a time faulty!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
279k this week end.. going better then ever!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
You need to put your full update on here including the fix Paul
You've know beaten the highest mileage I've had in a hdi engine now!
- x 8423
Game on for 300K then Paul
citroenxm
- Fallen Hero
- x 70
I have done the Full Fix on her on previous pages, it was the fuel regulator on the end of the pump...
Simple As!
Yea, not sure Ill get there Still Jim, heater matrix IS showing early signs of leakage, with a slight curry smell and windows steaming up rather then demisting..
Simple As!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
Have you bought some forte stop leak and bought yourself sometime as that may help get here there? And for you a heatermatrix job isnt a biggy is it now
citroenxm
- Fallen Hero
- x 70
NOPE!
I religiously DO NOT beleve in adding ANY sort of stop leak what so ever to any cooling system! if its stopping a leak, what else is it blocking up!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3298
There is one thing. IIRC Valeo require you to use Forte stop leak when fitting one of their heater matrixes for their warranty to be valid. I have got this from somebody else posting it up on the forum.
citroenxm
- Fallen Hero
- x 70
Why on earth would you put in a stop leak after fitting a new part! I NEVER have on ALL the Matrix's Ive done!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3298
I don't know, Paul, as I have yet to have the pleasure of doing one. All I can say it that several posts indicate Valeo insist on Forte Stop Leak as part of the installation process for their warranty to be valid;
http://www.frenchcarforum.co.uk/forum/v ... ix#p371593" onclick="window.open(this.href);return false;
I found 25 posts under a search for 'Valeo Forte Matrix'.
EDIT; Maybe it is like putting Fernox into a new central heating system to prevent any lime scale from forming and causing future problems?
