Berlingo battles and DRKpers
- x 3304
Re: Berlingo battles and DRKpers
Mike, I would love it, but I don't have the space or wherewithal for it.
However, if a second set of eyes could help get those brakes working let me know.
- x 94
its probably those stupid cone shaped retaining springs not seated properly Mike,northern_mike wrote: For some reason the shoes popped out of position, not once, but twice,
they can try anyone's patience,
what i do is have the eyelet blade thingy vertical and the hook end of the spring, put a blade of a flat bladed screw driver through the open/outer end of the spring, and with the blade horizontal so it can push and tilt the hook end of the spring,
now with the other hand rotate the base at the back/outside of the back plate of the eyelet till the eye goes over the hook,
hope this helps,
Regards, malcolm.
- x 94
nudge nudge
howz derk's brakes coming along Mike
Regards, malcolm.
Northern_Mike
- x 8350
Drum brakes are the work of the devil Mike..
Stop looking angrily at it. have a few days off and then walk up to it with purpose and show it just who's boss and the request with some authority that it gets its act together and starts behaving otherwise you'll set CitroJim onto it...
Seriously, if it's still peeing you off in early June, I may be able to offer you a day...
- x 3304
And if that doesn't work I have a 1kg lump hammer that you can borrow!
daviemck2006
- x 496
And if all else fails I'll give you the c2, a macdonalds happy meal, a Mars bar, and a citroen sticker for it.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8350
Careful Davie, the happy meal might just swing it for Mike but only if it still has the toy in it...daviemck2006 wrote:And if all else fails I'll give you the c2, a macdonalds happy meal, a Mars bar, and a citroen sticker for it.![]()
- x 3304
Not to put you off, Davie, but I think your son will then say something like "As you wouldn't get me a quad bike I'll use this instead", especially if you get the race tuned engine fitted!
Northern_Mike
It will definitely still be peeing me off by then Jim, it's the devil's own vehicle! I have gone as far as getting a gunsons' ezibleed thing to bleed the brakes for the next attempt.CitroJim wrote:Drum brakes are the work of the devil Mike..
I think some of the pingfuckit springs that Malcolm mentions are *old* and may have shortened. I'm not 100% sure.
Northern_Mike
Ha! Your profanity filter didn't get that one :-p
Northern_Mike
It's actually the only vehicle I've driven for 22 hours without a break, and you know what, not a single ache or pain after that.daviemck2006 wrote:And if all else fails I'll give you the c2, a macdonalds happy meal, a Mars bar, and a citroen sticker for it.![]()
- x 3304
And THAT is a very good reason to keep it!northern_mike wrote:It's actually the only vehicle I've driven for 22 hours without a break, and you know what, not a single ache or pain after that.daviemck2006 wrote:And if all else fails I'll give you the c2, a macdonalds happy meal, a Mars bar, and a citroen sticker for it.![]()
addo
- Sara Watson's Stalker
- x 95
- x 94
i think you need to rip out all that orible Rhino= renault junk and fit dershy bits instead
Regards, malcolm.
