Lucas EPIC Injection Pump Overhaul Guide
MadmartUK
Re: Lucas EPIC Injection Pump Overhaul Guide
Unread post by MadmartUK »
all together and wont start i think the output/plunger assy shaft one with plungers is 180 degrees out as i didnt see the tiny port on shaft . disassembling now
will update
x 8363
Looking forward to an update...
MadmartUK
pump was 180 degrees out in process of changing.
on turning over the speedo went full deflection and is now stuck on 150mph as battery was low. now on charge
any ideas how to rectify speedo?
just spoke to my Citroen man and looks like i need to take clock out and shake it round.
Update:- Car running , i was right the output shaft was 180 Degrees out. now for clock removal
i hope this info helps others and thankyou all for your help
Martin
x 8363
Martin that's excellent news :-D
On the subject of the clocks you may find it sometimes returns on it's own. It's a common enough problem with a low battery and some manage to nudge the errant needle back with a thin wire poked through the trip reset hole and others drill a tiny hole in the glass and use that to send in a wire to do the nudging.
I'd rather remove the clocks wholesale and give them a tilt. It's not too bad a job in an S2...
MadmartUK
Cheers jim
clocks all done in about 45mins removed and tilted easy as chips
thanks for all the tips and help on here brilliant forum guys with a lot of info and help
i hope no one else gets pump 180 out but i did it in situ the removal of the solenoids and output shaft was easier than taking the pump completely out of the car
Many thanks and im happy my cars running again and saved several hundred pounds doing it my self
Car MOTed Flew through on emissions first go happy happy happy
Indy406
New User
Unread post by Indy406 »
Hi guys, I've got a 1997 Peugeot 406 2.1 12v which has done 86,000. It's been a great car but has developed a intermittent timing rattle, sometimes it happens every time you turn the key for a week then nothing for 2 months. I've spoken to various people who have very little knowledge on the Lucas Epic pump however some people say it's the advance and retard unit on the pump. Some say it's the injector coil. Where is the advance and retard unit on the pump ? Is it straight forward to change ? Any advice would be appreciated. Thanks
smorcr
New User
Unread post by smorcr »
all bak in and ready to go prob is the pump is emty do i just crack and crank and crank till it starts ? mines a transit but same pump let me know would like to know
x 8363
You need to prime it first.... Get it full of diesel before making any attempt to start...
haroonstar77
Unread post by haroonstar77 »
hi everybody, I really need some help, I accidently removed one of the diesel delivery nosel from my pump epic lucas ( one of 4 in the back side of pump) . there are 4 small parts inside, and I don't know how to settle them inside. please help I am stucked. does anyone know the placement scheme fot it ?
x 8363
Sadly, I no longer have any EPIC pumps here and cannot remember precisely but if you can post up a picture of the parts I can very possibly tell you the order of reassembly...
haroonstar77
Thanks for your reply, I am new to the forums, i dont know how to upload pictures, but here is a link to my site http://designmax.fr/epic . thanks in advance for help .
haroonstar77
and only one nosel has these parts. i tried to open carefully other nosels to see the assembly. but the other 3 nosels look empty.
haroonstar77
finally, here is the pic.
x 8363
Excellent. I shall consult what documentation I have and let you know...
haroonstar77
I really appreciate your help. I am stucked at this point. when i removed the nozzle it just came out apart. and it wont fit anyways. I tried all possible assemblies. but no success.
