LHM change question
x 3296
Re: LHM change question
The problem with hydraflush is that it is not as 'greasy' as LHM, so (while it helps clean out the pipework etc.) after a while (3,000 miles +) things could start seizing up. However, in my experience it normally takes less than 2 hours to remove the hydraflush, clean the tank and filters, pop in LHM+, get the levels correct and bleed the brakes.
I would be inclined to try and get as much hydraflush as possible out in one go. It is inevitable that some will remain in the loop, but this shouldn't be a problem if this is kept to the minimum.
x 5673
If it is any help to you Mike then there is an enclosed car park at the rear of my house where I do my 'servicing' and you would have decent all-round access. I have a 25 litre container to dispose of the hydraflush too, and a few tools if needed.
Your biggest problem is going to be the bleed nipples, should they be reluctant to come out and shear.
x 8406
Mike, I've syphoned LHM out in the past but don't 'start' the syphon by sucking on the pipe. I can tell you from experience that LHM tastes foul!
Bleed nipples in my experience are rarely a problem. Rears I wire brush and soak in Plus Gas and then use a high quality socket on them to initially start them.
Bleed Nipples on LHM cars are nowhere near the nightmare that bleed nipples on cars with conventional brakes can be...
x 3296
I cheat when I empty the LHM. I have a small hand pump that I use to get the LHM into my drain tank. Very little mess, and less hassle.
x 8406
That's a good idea James :-D
x 3296
It makes LHM changing so much easier, and a LOT less messy!
Old-Guy
x 26
Unread post by Old-Guy »
To siphon anything nasty, put a 'breaker reservoir' in the line.
Any plastic bottle with a larger than normal cap is suitable; just drill two holes slightly smaller than the (clear) plastic pipe. IN pipe goes to the bottom of the bottle, OUT pipe (the one you suck on!) just through the cap. The IN pipe has to be long enough for the initial syphon into the bottle to work.
Once the bottle is full, the OUT pipe adds to the syphon. You can safely suck to get the syphon started and while the bottle fills you have time to put the open end of the OUT pipe in a big container.
A clear bottle is best - I've got a 500ml clear bottle that once held fruit juice - but a plastic milk bottle would do. I use it for LHM and fuel. Regularly drain the mower tank each autumn.
You can reduce the residual amount of LHM or Hydroflush by de-pressurising the hydraulics and leaving her sitting on the floor (car not wife).
x 8406
Guy, that's excellent. We can syphon to our heart's content and never have to worry about the horror that is the taste of LHM ever again.
Thank You :-D
isisalar
x 3
Unread post by isisalar »
I got a sort of giant bicycle pump thing from local factors, cost about a tenner. Can get about 95% of the LHM out of the tank without removing it and transfer the waste easily, draining takes about 10 minutes. 'Simples'
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 5673
There is also this from Aldi for around a tenner.
Siphon Pump
Clogzz
x 40
Unread post by Clogzz »
Washington the dump
http://www.frenchcarforum.co.uk/forum/v ... 30#p405069" onclick="window.open(this.href);return false;
That's not Washington the dump, it's a beautiful place. :)
Old-Guy
x 26
I forgot. Guy's patent syphon break doubles as a Xantia brake bleeding kit - it's a good idea to stand the bottle in an old ice-cream tub or similar in case it falls over while you're fiddling with the bleed nipple.
x 695
Unread post by Mandrake »
CitroJim wrote:Guy, that's excellent. We can syphon to our heart's content and never have to worry about the horror that is the taste of LHM ever again.
Thank You :-D
Yes indeed, pure genius, I must remember this trick next time I'm doing difficult siphoning. =D>
I don't actually find an accidental taste of LHM all that bad Jim, I find petrol much worse! :lol:
x 695
Don't know the exact figure but its more like 5 litres.
There's about half a litre just between the high and low marks!
x 5673
It is indeed Mike.
Blossom is practically gone now, house is full of it :(
That Aldi siphon pump is marked down to a fiver now (just been there).
The bit where my car is parked in the photo is pretty flat and the place I do my oil changes.
I'll get a sheet of cardboard from work in case of spillages. No-one will complain but it doesn't hurt to keep the place clean and tidy.
