Tuning box - but where?
MonkeyMark
Unread post by MonkeyMark »
I've been given a tuning box (I know, not as good as a remap ) but the c8's engine bay is so cramped I can't find the correct plug for love nor money.
Can anyone tell me where it's located please?
Happy(ish) C8 owner.
Lighty
x 35
Re: Tuning box - but where?
Unread post by Lighty »
The plug is located on the underside of the fuel rail, it's at the front of the engine. The plug is red , and just slightly to the right of the fuel filter, but very difficult to get to.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
MonkeyMark
Lighty wrote:The plug is located on the underside of the fuel rail, it's at the front of the engine. The plug is red , and just slightly to the right of the fuel filter, but very difficult to get to.
Thanks for that. Your not kidding its hard to get to. I can get my hand onto it but cant quite flick the catch to remove it. Ill try again later.
While im looking for plugs i found this one. It just below the fuel pump, the higher of the two there. A grey plug with two brown cables going into it. The cables are worn through the insulation to the piont where one only has two copper strands still holding. Its frayed right into the back of the plug so cant even cut and crimp.
Can anyone tell me what type of plug it is and maybe where i can buy one from?
http://www.caravantalk.co.uk/community/ ... -dsc-0177/
Cant get the picture to work so hope the link works instead.
x 1240
Unread post by Peter.N. »
You can I believe connect it to the other end of the cable but I have found that even more difficult to get at than the fuel rail.
MonkeyMark
Managed to cut and remake the faulty plug so thats sorted.
With the tuning box, the red plug is two pin. Can anyone confirm thats they correct plug? The tuning box I was given is three pin so either ive got the wrong box or the wrong plug.
Northern_Mike
The two pin and three pin boxes are for different fuel systems. One is for Siemens the other Bosch, but I can't remember which is which.
x 1487
Bosch uses a 3 pin plug.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Bear in mind the c8 uses the 2.2 16v engine not the more friendly 2.0 8v engine.
not sure if the rail is in the same place on the 2.2 .. I know the inlet is in the way though...
A very sad...
1994 XM 2.1 d auto
MonkeyMark
citroenxm wrote:Bear in mind the c8 uses the 2.2 16v engine not the more friendly 2.0 8v engine.
Mines a 2.0, not a 2.2.
Lighty
x 35
Lots of 2.0 16valve C8,s, I have a couple of tuning boxes at work, will check on the pin nos, you ain't having them for free though :)
Citroen C15
Citroen Ami
citroenxm
Fallen Hero
x 70
Ahhh the 2.0 16v 138 did make the C8. Well thats GOOD news, I hear the 2.2s make a habit of breaking belts because of the poor design or blocking of the drain channels that then lets water into the cam belt area.
A very sad...
1994 XM 2.1 d auto
MonkeyMark
I believe mine is something like 107bhp
SaabC5
Unread post by SaabC5 »
If you look at the injectors there's rubber pipes running between them on the Bosch system, no pipes means Siemens system.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
MonkeyMark
Lighty wrote:Lots of 2.0 16valve C8,s, I have a couple of tuning boxes at work, will check on the pin nos, you ain't having them for free though :)
Did you happen to have one of these at work?
robert 217
New User
Unread post by robert 217 »
Hi just bought a CRS tuning box for C5 1.6 HDI but can not find the plug to conect to looking for help thanks
