V6 Xantia......... the beginning of another adventure
Trainman
(Donor 2018)
x 43
Re: V6 Xantia......... the beginning of another adventure
Unread post by Trainman »
I've been having a little think this afternoon, so all you Oracle's here's the thought process:
I'm pondering disconnecting the mod to see if there is any difference in the starting, therefore if the starting is the same then it's the battery, if it starts easier then the mod is wrong, if so, it can only be a faulty relay......
Thoughts please
Steve
http://c6owners.org/index.php
x 8378
Trainman wrote: Thoughts please
It's always worth a go Steve.. Nothing at all to be lost..
Will, on the keygens. I've seen where the field containing the generated keygen is one or two characters too short to display it all and you need to horizontally scroll the field to see it all...
Confused the heck out of me once...
x 695
Unread post by Mandrake »
What keygen ? I've never had to use a keygen to install Diagbox...
Don't bother trying to install a standalone copy of Lexia - it will be ancient and more difficult to install. Just install the latest version of Diagbox on the discs - it contains a copy of Lexia for the older cars. (In fact you can't install Diagbox and the old standalone version of Lexia on the same machine - see another thread in the forum active just now)
If you're still having problems start your own thread in the Citroen section or join one of the other active Lexia threads so we don't drag Steve's thread off topic! :twisted:
x 3306
I had to use a keygen for the Citroen manual DVDs, but not for the Lexia stuff.
KP
x 27
Unread post by KP »
Ahhh!!! Time to rip the installs out of the virtual machine then and start it from scratch. Why can't an install be so much simpler lol
Trainman
(Donor 2018)
x 43
Re:
That's along my line of thinking...... :wink:
superloopy wrote:Steve ... how can you 'undo' the mod? It's unlikely to be the relay, wiring up is simples and wires have now been clipped surely? You would need to completely undo it. I'd be swapping in a good battery. I did ... a Bosch Silver 76ah. No problems at all.
Mike, There is one one wire that had to be cut and spliced, the others are additional wires, positive and earth, unless of course Will and I have completely botched something up, I ordered the part from the same company that was on the instructions, the only thing was that we couldn't find the 'white' plug so took the feed from somewhere else, where, I can't recall at the moment. :roll: therefore, my thought process is to reverse the fitting procedure .........
I was thinking of doing this before going down the road of replacing the battery with a new, huge ampage one........
Steve
KP
x 27
Unread post by KP »
IIRC the wire that we cut could simply be connected up with a SPADE-SPADE connector and that would put it back how it was.
If you plump for a new battery look for the varta equivalent of a Bosch S5 as they are strong batteries for the size, youve seen the spare one i have in the garage and its little brother ;)
I think 80AH is the largest size you could fit in a xantia tray but id play safe and find a 75AH one.
Do you want me to swap the one out of my TD at all and drop it off to you for testing? I know thats a good battery as the TD was left for weeks at one point and it still fired her up without issues and the 1.9td's are hard on batteries for starting :)
Trainman
(Donor 2018)
x 43
I'm going to do the disconnect first, which will probably be either tomorrow or Sunday and take it from there, worst comes to the worst, I can get it off you one morning next week on the way to work.
Steve
x 3306
Just a thought. What is the state of the battery leads?
KP
x 27
Unread post by KP »
Battery leads ok, and power wasn't taken direct from the instructions which was another supply in the box.
The negative ran to the battery directly though :)
I just followed the electrical diagram bits as best u could and from the pictures :)
x 3306
It was just a thought, as the leads might have been dodgy even though you weren't working on them.
Trainman
(Donor 2018)
x 43
The ones post somewhere on here, plus Sir Jims diagram, I can remember who sent me them, will have a look when I'm not trying to do this on my phone.
Steve
KP
x 27
Unread post by KP »
We took the positive from the one for the headlight washer relay mounting as it wasn't being used iirc.
I have slept since then a few times but the pics should clear it up :)
Trainman
(Donor 2018)
x 43
On mine there was no white plug, and that presented us with the problem, what I'm thinking now, is to take a direct feed from the battery. And then rejoin the wire we spliced to give us the power
Steve
x 3306
What I meant was the general state of the battery leads themselves. If any were breaking down I would wonder if that would give starting problems despite the relay mod being done?
