V6 Xantia......... the beginning of another adventure
Moderators: RichardW, myglaren
Trainman
Donor 2018
x 12
Re: V6 Xantia......... the beginning of another adventure
Post by Trainman »
CitroJim wrote: Mike? Mike who??? No-one in WFA called Mike unless we have a new member in which I'm no longer a third but just a quarter... :lol:
JEEZ I'm losing the plot :roll: I have no idea why I said Mike I should have said Chris (Chris570)
muttering to himself as he wanders off................................ :roll: :roll: :roll:
Trainman
Donor 2018
x 12
Post by Trainman »
Will and did the mod this morning, well actually, more Will than I.................
Here's a shot of the fuse box prior to the work beginning.....
As you can see, there is no relay for the wash/wiper this made the job a busy easier......
Lifting the sockets out you can see the wiring underneath
The next few shots show different stages of the wiring process.....
KP
x 7
Post by KP »
Don't forget to check those battery clamps as well Steve after the trip back :)
Glad I could be of help and fingers crossed this sorts out your starting issue, and Saves the ignition switch long term :)
x 1780
Post by CitroJim »
Excellent work gents!
That'll have the problem licked for sure...
DHallworth
Donor 2016
x 74
Post by DHallworth »
Nice one! Fingers crossed it cures the fault.
Steve - You really have had your patience tested by that car!
David.
Trainman
Donor 2018
x 12
Post by Trainman »
KP wrote:Don't forget to check those battery clamps as well Steve after the trip back :)
Will, Thanks for today =D> =D> I have no idea with electric's let alone diagram's :oops:
CitroJim wrote:Excellent work gents!
I hope so Jim, although I'm not so sure, We changed the battery for a higher amphere one, but I'm not sure the battery is strong enough, I'll know better tomorrow. When I started her straight back up after getting home from Will's she seemed to take a while to started, almost like she was pumping fuel through.
DHallworth wrote:Nice one! Fingers crossed it cures the fault.
David.
David, I would like to say it's been a pleasure but it hasn't! The good thing now though is that I'm beginning to see light at the end of the tunnel.
KP
x 7
Post by KP »
If there's any issues with the battery we can try swapping back Steve as I put yours on to recondition soon after you left and it's almost done now. To be honest I think the biggest you can go is about 72ah in yours so we could always try the one from my td if it helps? That spins the td after 2 glowplug runs very easily :)
KP
x 7
Post by KP »
Ps always happy to help :)
Thanks for the lexia time and he ios image :) working a treat as we speak!
Trainman
Donor 2018
x 12
Post by Trainman »
KP wrote:Ps always happy to help :)
Excellent =D> that means I have to burn a copy for a lad at Runcorn with a Peugeot now........ #-o
Battery wise, I'm going to see what happens over the next couple of days...... :|
KP
x 7
Post by KP »
I'll be up Preston way Thursday afternoon evening so happy to bring it with if needed :)
Trainman
Donor 2018
x 12
Post by Trainman »
Unfortunately I won't be will be at work, having said that I won't be leaving until 2pm, so we'll see. I will spin her over later and report back. I will also check the battery connections at the same time as I replace the horns.
#FingersCrossed
KP
x 7
Post by KP »
Good luck fella :)
I'd be up around lunch time so I'm sure we could work something out :)
Trainman
Donor 2018
x 12
Post by Trainman »
I've worked through the horn replacement this morning, out of the 4 I had, I've now got 2 working ones, so that now, instead of the polite 'excuse me' I now have ones that say BOG OFF!!
I'm still not sure about the starter, having said that, I've rechecked the battery connections this morning and whilst not loose, I've had them off and sanded the connections clean, so I'll give it until tomorrow and see what happens 8-[
x 1780
Post by CitroJim »
Two out of four ain't bad... As Meatloaf might have said...
Your 'excuse me' horn reminds me of the Town and Country horns on the DS. A genteel one for urban use and a rorty one for when out in the open!
Fingers crossed on the starter Steve...
Are the battery terminals bad then?
Trainman
Donor 2018
x 12
Post by Trainman »
No Jim, I just wanted to eliminate another possibility, it's weird, it seems to be struggling to start but fires first time, almost like the battery isn't powerful enough.
