Drive level 2 AirBag
painterman7
Hi, Can anyone tell me where the driver level 2 air bag is, as my Lexia says that the circuit is open, and any idea as to fix. Thanks
- x 3296
Re: Drive level 2 AirBag
First question, what is the vehicle?
- x 1488
It will be level 2 igniter. There are 2 igniters in the air bag (level 1 and 2). Most likely the ribbon cable in the COM2000 has failed. Might be repairable, otherwise replacement, which ranges from £100 - £300 depending on model and source of replacement.
painterman7
Thanks, Sorry forget to mention a C5 mk1 2002. took it on a drive this morning then hooked up Lexia to find its gone from permanent fault to Temp, so cleared. I will check tomorrow if OK will arrange MOT asap
painterman7
If it should happen again which bag does it refer to, seat or steering wheel? I know where the seat connectors are but not the s/w one is in case it just needs cleaning, appreciate any info.
- x 1488
It's the bag in the wheel. The problem is the 'COM2000' which is the unit that sits behind and consists of the column stalks, and the rotary connector for the air bag and horn. You can try cleaning the contacts, but it doesn't seem to suffer like that - it's just that the ribbon cable breaks up over time....
painterman7
Any ideas where I can get a cheap repair to get through the MOT, Or can I purchase the part cheaply and get the DIY Instructions from your good selves to do it.
BenC5HDi
- Not Mike
- x 45
Contact this chap, Graeme Hall... he's in Bradford but you can remove your comm 2000 and send it to him, or take your car to him and he will do it while you wait..
http://m.ebay.co.uk/itm/COMM-2000-PEUGE ... 2036624369
Sent from my SM-N9005 using Tapatalk
painterman7
What's involved in removing it as I'm Berkshire
BenC5HDi
- Not Mike
- x 45
Remove battery, remove airbag, disconnect airbag and steering wheel radio controls , remove steering wheel. The comm 2000 has one, maybe 2 10mm bolts to undo and some plugs. Then it lifts out.
painterman7
Thanks, any chance of part number? Mk1. 2.0ltr Lx. 2002 estate.
- x 1052
May well be the connectors under the carpet in the passenger footwell, very common problem & a lot cheaper than a com2000.
See here> http://www.frenchcarforum.co.uk/forum/v ... s+footwell
painterman7
Would this still show up as level 2 ignighter?
- x 1052
Can be either level one or two, both the connectors are there for each. The car was desinged as LHD. Those connectors are where the airbag loom is extended over for RHD. The fault code means there is a fault on the circuit & it could be anywhere between the airbag ECU & the airbag itself, the two weakest points are those connectors or the rotary ribbon cable in the com2000. The ECU or the airbag itself could even be faulty but the cheapest place to start is the footwell connectors.
painterman7
Great explanation, I will start exploring, thank you very much again you have been a great help. Regards. Jack
