picked up my Exclusive Estate 2 liter hdi
jacksun1987
Re: picked up my Exclusive Estate 2 liter hdi
Pads and disks are ok he did say I need a accuminater spher and the systerm does need bleeding and changed Lhm fluid
citroenxm
- Fallen Hero
- x 70
Ah well. POOR Fluid and a flat accumilator sphere will not help the brakes At ALL!
Sounds like a list of small and easy things to do then..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Eddie Nuff
- New User
- x 32
jacksun1987
Do I need a special spher or can I just put any in Euro car parts have sphere but it says no accuminater one
citroenxm
- Fallen Hero
- x 70
Yes A SPECIAL one, needs to be an Accumilator Sphere, nothing else..
Try AEP Direct, also known as Citroen Services... They are BETTER then ECP or GSF...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jacksun1987
http://www.aepdirect.com/accumulator-sp ... ory_id=755" onclick="window.open(this.href);return false;
is that the one. If it is ive saved 10 pound on price 44 pound on fitting labure 14 pound part 30 pound
Its just the time. Only got monday off working sunday The mot runs out properly on the 6th of march
citroenxm
- Fallen Hero
- x 70
Yes Paul, thats the one!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jacksun1987
got parts from bullwikles Saves messing about
Got some tyres frm the scrap yard 48 pound for 2 plus fitting. But they couldnt balance them. The ally wheel hassnt got that center cap thing on it. If it was normal bog standard wheel. He could have put it on machine.
Feels rubbish now it does. S need find somwhere to balance them and do tracking.
On one of the jobs. Just needs break pads cleaning.. greasing up etc. would have been 50 pound in labure to clean everything down.
Thats the only problem with bullwikles cant read his writing lol.
jacksun1987
surly if i took them to a proper garage or tyre place they can sort them
Northern_Mike
Some areas seem to have no places that can do them. I have no problem down here at any of the places I use. Weird.
Northern_Mike
48 quid for two plus fitting is expensive for part worns! Place on the A4 in Slough charges 15 inc fitting and balancing!
jacksun1987
We have done 2 jobs cleaned the break pads and changed all if the bulbs today should get it done before friday
jacksun1987
put the break pads back on drove it home. The handbreak seems higher up when on. And the break light is on
jacksun1987
The frount nearside was k to do. Then we disconnected the lose handbreak cable because it wasnt doing anything.
Started the offside one. Took us ages to lift the calliper. So we was hanking and pulling on that. Then when we put the pads back on. The piston was not going in. So we was forcing that
Northern_Mike
The piston screws in. If you've forced it you've likely knackered the caliper and could be why your handbrake ia high. How much is left on the pads anyway? If the efficiency is so bad it shows up on the MOT something is knackered big time.
